[Feature request] Snap palette to command dialog
rolandas_vegis
rolandas_vegis
We are trying to use a command which uses both a command dialog and a palette. It all works nicely, you can even snap them together using Fusion UI. The only problem is that palette does not remember that it was snapped to a command dialog on re-open.
Palette object has a method snapTo which allows you to snap a palette with another palette. It would be nice to have the same method which would work with a palette and a command dialog.
nnikbin
Nice idea. We need this feature too.
