Extrude-Cut in API (and also Interactively)
I am writing a simple command, wish takes a profile and calls Extrude-with-Cut-boolean. For this the code I have written is:
    def Execute(self, selectedProfile):
        if not isinstance(selectedProfile,adsk.fusion.Profile):
            return;
        app = adsk.core.Application.get();
        doc = app.activeDocument
        d = doc.design
        rootComp = d.rootComponent
        extrudes = rootComp.features.extrudeFeatures
        extrudeInput = extrudes.createInput(selectedProfile, adsk.fusion.FeatureOperations.CutFeatureOperation)
        distance = adsk.core.ValueInput.createByReal(.5);
        extrudeInput.setDistanceExtent(False, distance);
        extrude = extrudes.add(extrudeInput)
But it fails saying that, 'No body to intersect/cut' was found. But I had drawn cut-profile-sketch on a face of a body. That body should have been the obvious choice to cut with the computed tool-body.
Interactively also it fails. After searching some posts here, it seems that its bit inconsistent. sometimes it works.
Any clues?
david_reaume
To perform a cut in the scenerio you're dealing with, you'll need a negative value for the distance.  Choosing the cut operation does not automatically flip the positive direction of the extrude to point into the body to be cut.
So you should try:
distance = adsk.core.ValueInput.createByReal(-.5);
Happy Coding!
DaVeR
DaVeR
Perfect!!! Thanks a lot.
