ExtractBOM "Addin" - Add Description & Material Properties
isocam
isocam
Can anybody help???
I need the standard "ExtractBOM", that is downloaded with Fusion 360 modified to show the "Description & Material Property" of each part. I do not need the "Volume" property.
Has anybody modified the Addin to do this?
Many thanks in Advance!!!!
Darren
marshaltu
Please try the following codes and see if they are what you want.
Marshal
import adsk.core, adsk.fusion, traceback
def spacePadRight(value, length):
    pad = ''
    if type(value) is str:
        paddingLength = length - len(value) + 1
    else:
        paddingLength = length - value + 1
    while paddingLength > 0:
        pad += ' '
        paddingLength -= 1
    return str(value) + pad
def walkThrough(bom):
    mStr = ''
    for item in bom:
        mStr += spacePadRight(item['name'], 25) + str(spacePadRight(item['instances'], 15)) + str(spacePadRight(item['material'], 25)) + str(item['description']) + '\n'
    return mStr
def run(context):
    ui = None
    try:
        app = adsk.core.Application.get()
        ui  = app.userInterface
        product = app.activeProduct
        design = adsk.fusion.Design.cast(product)
        title = 'Extract BOM'
        if not design:
            ui.messageBox('No active design', title)
            return
        # Get all occurrences in the root component of the active design
        root = design.rootComponent
        occs = root.allOccurrences
        # Gather information about each unique component
        bom = []
        for occ in occs:
            comp = occ.component
            jj = 0
            for bomI in bom:
                if bomI['component'] == comp:
                    # Increment the instance count of the existing row.
                    bomI['instances'] += 1
                    break
                jj += 1
            if jj == len(bom):
                # Add this component to the BOM
                bom.append({
                    'component': comp,
                    'name': comp.name,
                    'instances': 1,
                    'material': comp.material.name if comp.material else '',
                    'description': comp.description
        # Display the BOM
        title = spacePadRight('Name', 25) + spacePadRight('Instances', 15) + spacePadRight('Material', 25) + 'Description\n'
        msg = title + '\n' + walkThrough(bom)
        ui.messageBox(msg, 'Bill Of Materials')
    except:
        if ui:
            ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
Marshal Tu
Fusion Developer
Apologies for reviving an old thread. I am looking for help regarding adding length, width and thickness to the extractBOM popup. Have tried reading and hacking at the python code to no avail.
Also, is there a way to have extractBOM as a toolbar button in Fusion360, or at the very least a shortcut?
Many thanks
