Problem Installing Fusion 360 plugins
Message 1 of 9
I have a problem i have installed a few plugins,
but a always get this pop up and my plugins doesnt work, can someone help me with this?
See the attachment to see my problem
Kind regards
Replies (8)
Message 2 of 9
marshaltu
You may have to configure the addin before using any bolter commands according to the error message.
Marshal
Marshal Tu
Fusion Developer
Message 3 of 9
Hello thx for the reply
i already tried to but then i get this message.
im pretty new to fushion so i it a bit confusing adding the plugins.
Kind regards
Message 4 of 9
Kind regards
Message 5 of 9
marshaltu
Unfortunately I didn't know more technical details about the addin. @prainsberry can probably give some clue what's root cause. He is the author of the addin.
Marshal
Marshal Tu
Fusion Developer
Message 6 of 9
prainsberry
Hey from looking at that error i think maybe there is a mistake in the way i am setting up the initial google sheet.
I was doing it by making a copy of an existing one i already created.
I think maybe the google sheet API won't let you access it in this way.  Are you getting that error when click configure, or just when it starts running?
I might have to make a big change if the google sheet API doesn't support this, but it is the first time i've heard it so maybe not.
Patrick Rainsberry
Developer Advocate, Fusion 360
Message 7 of 9
It hapens everytime i click confirure fushion bolter then , i try to create new sheet, then i press ok and then i get the error message.
Message 8 of 9
prainsberry
At some point you should have gotten a message asking you to 'authorize' bolter to access your google sheets account.
Do you remember doing this?  If not then i think there may be a much bigger issue, and i'll likely pull the app down for now.
Patrick Rainsberry
Message 9 of 9
I remember that I have authorize bolter to access my google sheets account.
