Exporting A design to multiple STL's with their location ant rotation data.
Hello All,
I'm enjoying Fusion360 so much, I'm wanting to dig deeper and seeing what can be automated.
Right now I'm using Fusion360 for modelling and Blender Cycles for rendering, which means I have to Export to STL.
The most ideal setting for me with the default STL exporter is to export as multiple files. It works well, however, it exports single bodies, and creates rather convoluted filenames, that are a pain to work with.
I've written this simple script that exports occurrences, which means I can have a component with separate bodies, acting as one part. However, they get imported at their own origin, with no location or rotation data. Which means that when I import all into Blender, I get a huge mess of parts (Components), whereas using Fusion's Built-in exporter, I get all parts (Bodies) in their rotated (and moved) positions.
The ideal order of events for this operation are:
1. Press a button "STL Export" (not included in the code)
2. Select folder
3. Files exported in "high" setting, with no extra dialogs (or user input), with their Component names.
Any simple solutions to this? Thank you all in advance.
Here's an excerpt of my plugin so far, it's a very rough draft - apologies for that;
class CommandExecuteHandler(adsk.core.CommandEventHandler):
    def __init__(self):
        super().__init__()
    def notify(self, args):
        try:
            app = adsk.core.Application.get()
            ui  = app.userInterface
            #msg = ''
            # Set styles of file dialog.
            fileDlg = ui.createFileDialog()
            fileDlg.isMultiSelectEnabled = False
            fileDlg.title = 'Fusion File Dialog'
            fileDlg.filter = '*.*'
            folderDlg = ui.createFolderDialog()
            folderDlg.title = 'Fusion Folder Dialog'
            # Show folder dialog
            dlgResult = folderDlg.showDialog()
            if dlgResult == adsk.core.DialogResults.DialogOK:
                #msg += '\nSelected folder: {}'.
                format(folderDlg.folder)
            #ui.messageBox(msg)
            product = app.activeProduct
            design = adsk.fusion.Design.cast(product)
            rootComp = design.rootComponent
            exportMgr = design.exportManager
            # export the component one by one with a specified format
            allOccu = rootComp.allOccurrences
            for occ in allOccu:
            # create stl exportOptions
                fileName = folderDlg.folder + "/" + occ.component.name
                stlExportOptions = exportMgr.createSTLExportOptions(occ, fileName)
                stlExportOptions.meshRefinement = adsk.fusion.MeshRefinementSettings.MeshRefinementHigh
                stlExportOptions.sendToPrintUtility = False
                exportMgr.execute(stlExportOptions)
        except:
            if ui:
                ui.messageBox('STL Export Failed / Cancelled')
kandennti
Hi petrikas.m.
"isOneFilePerBody"  property seems to be useful.
import adsk.core, adsk.fusion, traceback
def run(context):
    ui = None
    try:
        #export STL
        stlExportOptions = exportMgr.createSTLExportOptions(rootComp, folderDlg.folder + "/")
        stlExportOptions.isOneFilePerBody = True #This Property
        ui.messageBox('Done')
    except:
        if ui:
Hey @kandennti, thanks for the reply!
Yes, isOneFilePerBody fixes my immediate problem of position and rotation, but creates another - multiple files for the same component. For rendering, having all e.g. bolts in one component is a life-saver.
I guess I have to work with what I have.
Thanks again!
kandennti
It was possible to export with RootComponent using RootCompBodies and Occurrence LightBulbOn On or Off.
try it.
def run(context):
    ui = None
    try:
        root = design.rootComponent
        allOcc = root.allOccurrences
        #Save State LightBulbOn
        lightOnLst = []
        #rootComp BodiesFolder
        if root.isBodiesFolderLightBulbOn:
            lightOnLst = [root]
        #Occurrence LightBulbOn List
        occLightOnLst = [occ for occ in allOcc if occ.isLightBulbOn == True]
        lightOnLst.extend(occLightOnLst)
        #LightBulbOn All Off
        for itm in lightOnLst:
            LightBulbOn(itm, False)
        #export STL
        meshHigh = adsk.fusion.MeshRefinementSettings.MeshRefinementHigh
            LightBulbOn(itm, True)
            if isinstance(itm, adsk.fusion.Component):
                fileName = folderDlg.folder + "/" + itm.name
            else:
                fileName = folderDlg.folder + "/" + itm.component.name
            stlExportOptions = exportMgr.createSTLExportOptions(root, fileName)
            stlExportOptions.meshRefinement = meshHigh
        #Reproduction LightBulbOn
    except:
        if ui:
def LightBulbOn(obj, on_off):
    if isinstance(obj, adsk.fusion.Component):
        obj.isBodiesFolderLightBulbOn = on_off
    else:
        obj.isLightBulbOn = on_off
Apologies for resurrecting an old thread... And thanks @kandennti for your help!
Since newer Fusion360 replaced light-bulbs with "eye" icons, I'd need to update this script. Is there any documentation on it? Thanks in advance.
kandennti
Hi @Anonymous .
I'm sorry. I've already forgotten some of the details.
The icons have been changed to "eye", but the API property names should not have changed,
so I don't think there is any change in behavior.
http://help.autodesk.com/view/fusion360/ENU/?guid=GUID-7cd5b52f-26bb-4890-9c37-2dc48213d685
https://help.autodesk.com/view/fusion360/ENU/?guid=GUID-b56b394e-b9c9-4403-a78b-a186b897909c
