Export World geometry of sketch points
_fabschke_
_fabschke_
Hi there,
for my student project I need to export the coordinates of multiple landmarks of a bone.
For this case I put sketch_points on the landmarks on the bone stl and imported that in another fusion file.
Now i build a skript to export those sketch point coordinates into an csv file.
But the problem is that i get the same coordinates every time, unrelated where the bone is in the world.
I guess the false output is the coordinate of the point inside the bone STL but not in the enviroment which the STL are now.
How can I get the "real" world geometry that I also get in the down right corner when I select the sketch point?
Output:
8.88178419700126e-18,-5.813692761401534,-0.4320296700973223
which I clearly do not want it to be.
more like
0.0,7.704120366290506,17.327285482391748
0.0,10.99999975413084,20.069999551400542
0.0,12.089999729767442,21.599999517202377
Thank you guys in dadvance for your help
import adsk.core, adsk.fusion, adsk.cam, traceback, csv
app = adsk.core.Application.get()
ui = app.userInterface
# Initialize variables
i = 0
coord = []
templist = ()
#1
pntEntity = ui.selectEntity('Select a sketch point', 'SketchPoints')
pnt = adsk.fusion.SketchPoint.cast(pntEntity.entity)
templist = ('{}'.format(pnt.geometry.z), '{}'.format(pnt.geometry.y), '{}'.format(pnt.geometry.x))
coord.append(templist)
print(templist)
templist = 0
#1,2,3...... depends how many
print(templist)
templist = 0
print(coord)
Point = ['name_of_bone']
header = ['X-Coordinate', 'Y-Coordinate', 'Z-Coordinate']
coordinates = open('path/coordinates_calc.csv', 'a')
with coordinates:
    writer = csv.writer(coordinates)
    writer.writerow(Point)
    writer.writerow(header)
    for row in coord:
        writer.writerow(row)
In this example there you can see the 3 linked STLs and their sketch points which I select.
Bildschirmfoto 2019-10-21 um 15.07.44.pngThose are the linked bone STLs in which i created the sketch points
JeromeBriot
You have to use the worldGeometry property as I told you before.
Coordinate algebraic sign (-) in point geometry print command
kandennti
I can't explain because I'm not good at English.
The following code displays the position of all visible sketch points.
That is the "real" world position.
def run(context):
    ui = None
    try:
        des = adsk.fusion.Design.cast(app.activeProduct)
        #displayed sketches
        skts = [skt
                for comp in des.allComponents if comp.isSketchFolderLightBulbOn
                for skt in comp.sketches if skt.isVisible]
        #extension_method
        adsk.fusion.SketchPoint.toGeoTF = SketchPointToGeoTransform
        adsk.fusion.Component.toOcc = ComponentToOccurrenc
        #Get 3D coordinate values
        pos_lst = []
        for skt in skts:
            mat = skt.transform.copy()
            occ = skt.parentComponent.toOcc()
            if not occ is None:
                mat.transformBy(occ.transform)
            for skt_pnt in skt.sketchPoints[1:]:
                pnt3d = skt_pnt.toGeoTF(mat)
                pos_lst.append('{},{},{}'.format(pnt3d.x,pnt3d.y,pnt3d.z))
        #finish
        ui.messageBox('\n'.join(pos_lst))
    except:
        if ui:
            ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
#adsk.fusion.SketchPoint extension_method
def SketchPointToGeoTransform(self,mat3d):
    geo = self.geometry.copy()
    geo.transformBy(mat3d)
    return geo
#adsk.fusion.Component extension_method
#Get occurrence from component root is None
def ComponentToOccurrenc(self):
    root = self.parentDesign.rootComponent
    if self == root:
        return None
    occs = [occ
            for occ in root.allOccurrencesByComponent(self)
            if occ.component == self]
    return occs[0]
_fabschke_
@JeromeBriot
Yeah sorry I know. But when I used it the code did not work.
With the other answer after you I found my error. And of course you were right.It was just using the worldGeomertry property. 😉
Thank you again
@kandenntiThank you also. I found the error in my code thanks to your response 🙂
kandennti
In the above code, the correct value was not obtained.
Therefore, the following part has been modified and published here.
https://github.com/kantoku-code/Fusion360-ExportSketchPointsCoordinate
・ Deep component (occurrence) acquisition of correct value
・ Considering the unit when the user executes
・ Export as CSV file
marlon.weinert
Awesome! Thanks a lot, this is exactly what I was looking for!
