Event when HTML is loaded and ready?
sophiadoan
sophiadoan
I tried to sendInfoToHTML within CommandEventHandler which triggers after CommandCreatedEvent but the Palette does not response. May be because it has not been loaded and ready to receive?
I need to send data before user has a chance to click any thing on the palette.
I hope I don't have to spawn a task to poll for ready status.
Thank you
kandennti
Hi @sophiadoan .
I interpreted the initial value of the palette display to mean that you want Fusion360 to send some data to be displayed.
On the JavaScript side, use the DOMContentLoaded event to call the adsk.fusionSendData function.
On the C++ side, pick up the DOM side call with the incomingFromHTML event and send the necessary data to the JavaScript side using HTMLEventArgs.returnData.
https://help.autodesk.com/view/fusion360/ENU/?guid=GUID-DC2A4AB7-6A24-4A28-87A0-9952A0ABDF74
The content is in python, but I also learned it here.
https://forums.autodesk.com/t5/fusion-360-api-and-scripts/i-want-to-set-the-initial-values-for-the-p...
Note that the new browser (QT Web Browser) is asynchronous.
sophiadoan
window.addEventListener('DOMContentLoaded', (event) => {
adsk.fusionSendData('domLoaded', '');
above event did fired, but this is what I see in the Console error output:
VM41 ImagePanel.html:104 Uncaught ReferenceError: adsk is not defined
at VM41 ImagePanel.html:104
and HTMLEventHandler never get called until some button is clicked on the palette.
kandennti
@sophiadoan .
We could not reproduce the same error here.
Does JavaScript give the same error when I do this?
document.addEventListener('DOMContentLoaded', () => {
	let adskWaiter = setInterval(() => {
		if (window.adsk) {
			clearInterval(adskWaiter);
sophiadoan
@kandennti
I did not use polling (setInterval), with it now it works!
Thank you very much
