Feature.linkedFeatures property
kandennti
Mentor Mentor
Message 1 of 1
kandennti
Hi there.
Please let me know about the Feature.linkedFeatures property.
From the documentation description, it seems like I can get the related features.
https://help.autodesk.com/view/fusion360/ENU/?guid=GUID-7c8c7b91-476d-4e44-a557-11d45f7e27aa
I have created the following script and checked the linkedFeatures.count for some data, but it always returns 0.
# Fusion360API Python script
import traceback
import adsk.fusion
import adsk.core
def run(context):
    ui = adsk.core.UserInterface.cast(None)
    try:
        app: adsk.core.Application = adsk.core.Application.get()
        ui = app.userInterface
        des: adsk.fusion.Design = app.activeProduct
        if des.designType != adsk.fusion.DesignTypes.ParametricDesignType:
            return
        timeline: adsk.fusion.Timeline = des.timeline
        backupMarker = timeline.markerPosition
        lst = []
        for idx in range(timeline.count):
            timeObj: adsk.fusion.TimelineObject = timeline.item(idx)
            feat: adsk.fusion.Feature = adsk.fusion.Feature.cast(timeObj.entity)
            if not feat:
                continue
            timeObj.rollTo(True)
            before = feat.linkedFeatures.count
            timeObj.rollTo(False)
            after = feat.linkedFeatures.count
            lst.append(f'{feat.name} : {before} - {after}')
        timeline.markerPosition = backupMarker
        dump('** linkedFeatures.count **')
        dump('Feature Name : Before Count - After Count')
        dump('-------')
        if len(lst):
            dump('\n'.join(lst))
    except:
        if ui:
            ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
def dump(s):
    print(s)
    adsk.core.Application.get().log(s)
This script does not work in direct mode, but I have confirmed that the linkedFeatures property returns "None" in direct mode.
Is the linkedFeatures property working?
If so, under what data conditions can the features be retrieved?
(If the pattern's Object Type is set to feature, the count is 0.)
Replies (0)
