Drop down in panel drop down
brad.bylls
brad.bylls
I've added a drop down item to the Addins drop down list.
What I can't figure out is how to get them to work when I click on them.
I just want to click on them which will then run another script.
import adsk.core, adsk.fusion, adsk.cam, traceback
def run(context😞
    ui = None
    try:
        app = adsk.core.Application.get()
        ui  = app.userInterface
        addins = adsk.core.ToolbarPanel.cast(ui.allToolbarPanels.itemById("SolidScriptsAddinsPanel"))
        dropDown = addins.controls.addDropDown("DropDown""./Resources")
        cmd0 = ui.commandDefinitions.addButtonDefinition("cmd0""SHCS""Create a SHCS""./Resources")
        cmd1 = ui.commandDefinitions.addButtonDefinition("cmd1""FHSCS""Create a FHSCS""./Resources")
        dropDown.controls.addCommand(cmd0)
        dropDown.controls.addCommand(cmd1)
    except:
        if ui:
            ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
Brad Bylls
JeromeBriot
You should carefully read this part of the API documentation: Fusion 360 Commands
brad.bylls
After looking at the documentation link, this is what I came up with. Doesn't work.
I'm hoping it is just the execFile('SHCS') part that is not working.
Can't find how to run another script from a script.
handlers = []
def run(context😞
    ui = None
    try:
        shcsButton = ui.commandDefinitions.addButtonDefinition("shcs""SHCS""Create a SHCS""./Resources")
        fhscsButton = ui.commandDefinitions.addButtonDefinition("fhscs""FHSCS""Create a FHSCS""./Resources")
        # Connect to the command created event.
        shcsCreated = ShcsCreatedEventHandler()
        shcsButton.commandCreated.add(shcsCreated)
        handlers.append(shcsCreated)
        fhscsCreated = FhscsCreatedEventHandler()
        fhscsButton.commandCreated.add(fhscsCreated)
        handlers.append(fhscsCreated)
        # Get the ADD-INS panel in the model workspace.
        addInsPanel = ui.allToolbarPanels.itemById('SolidScriptsAddinsPanel')
        # Add the button to the bottom of the panel.
        dropDown.controls.addCommand(shcsButton)
        dropDown.controls.addCommand(fhscsButton)
    except:
        if ui:
# Event handler for the shcsCreated event.
class ShcsCreatedEventHandler(adsk.core.CommandCreatedEventHandler😞
    def __init__(self😞
        super().__init__()
    def notify(selfargs😞
        eventArgs = adsk.core.CommandCreatedEventArgs.cast(args)
        cmd = eventArgs.command
        # Connect to the execute event.
        onExecute = ShcsExecuteHandler()
        cmd.execute.add(onExecute)
        handlers.append(onExecute)
# Event handler for the shcs execute event.
class ShcsExecuteHandler(adsk.core.CommandEventHandler😞
    def __init__(self😞
        super().__init__()
        eventArgs = adsk.core.CommandEventArgs.cast(args)
        # Code to react to the event.
        execFile('SHCS.py')
# Event handler for the fhscsCreated event.
class FhscsCreatedEventHandler(adsk.core.CommandCreatedEventHandler😞
    def __init__(self😞
        super().__init__()
        onExecute = FhscsExecuteHandler()
# Event handler for the fhscs execute event.
class FhscsExecuteHandler(adsk.core.CommandEventHandler😞
    def __init__(self😞
        super().__init__()
        execFile('FHSCS.py')
def stop(context😞
    try:
        # Clean up the UI.
        cmdDef0 = ui.commandDefinitions.itemById('shcs')
        if cmdDef0:
            cmdDef0.deleteMe()
        addinsPanel = ui.allToolbarPanels.itemById('SolidScriptsAddinsPanel')
        cntrl0 = addinsPanel.controls.itemById('shcs')
        if cntrl0:
            cntrl0.deleteMe()
        cmdDef1 = ui.commandDefinitions.itemById('fhscs')
        if cmdDef1:
            cmdDef1.deleteMe()
        cntrl1 = addinsPanel.controls.itemById('fhscs')
        if cntrl1:
            cntrl1.deleteMe()
    except:
        if ui:
Brad Bylls
JeromeBriot
To test the menus, replace the execFile commands with something like ui.messageBox('Test')
Maybe:
subprocess.run([sys.executable, 'FHSCS'])
