Don't use progress dialog with large data
JeromeBriot
Mentor Mentor
JeromeBriot
I already faced this issue with other languages so I don't call this a bug.  I just want to warn people about this behavior.
Here is a code that runs two empty loops:
#Author-
#Description-
import adsk.core, adsk.fusion, adsk.cam, traceback
import time
def run(context):
    ui = None
    try:
        app = adsk.core.Application.get()
        ui  = app.userInterface
        elapsedTime = [0.0, 0.0]
        N = 25000
        progressDialog = ui.createProgressDialog()
        progressDialog.cancelButtonText = 'Cancel'
        progressDialog.isBackgroundTranslucent = False
        progressDialog.isCancelButtonShown = True
        progressDialog.hide()
        progressDialog.show('Speed test', 'Percentage: %p, Current Value: %v, Total steps: %m', 0, N)
        startTime = time.time()
        for i in range(0, N):
            if progressDialog.wasCancelled:
                break
            progressDialog.progressValue = i
            pass
        elapsedTime[0] = time.time() - startTime
            pass
        elapsedTime[1] = time.time() - startTime
        ui.messageBox('{:.1f} s\n{:.1f} s'.format(elapsedTime[0], elapsedTime[1]))
    except:
        if ui:
            ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
Now the results on my PC (i7-3700) for 25000 iterations:
  • First loop with the progress dialog: 13.2s
  • Second loop without the progress dialog: 0.0s
It's even worst on my Mac (i5-3210M):
  • First loop with the progress dialog: 208s
More results from a code in which I export mesh data to STL file with and without the progress dialog.
On my PC:
  • Low mesh refinement (3900 iterations): 2.0s / 0.0s
  • Normal mesh refinement (9000 iterations): 4.6s / 0.1s
  • High mesh refinement (26000 iterations): 13.1s / 0.3s
  • Very High mesh refinement (89600 iterations): 45.6s / 0.9s
Same results on my Mac:
  • Low mesh refinement (3900 iterations): 32s / 0.0s
  • Normal mesh refinement (9000 iterations): 75s / 0.1s
  • High mesh refinement (26000 iterations): 216s / 0.2s
  • Very High mesh refinement (89600 iterations): 745 / 0.8s
The progress dialog costs 0.0005 second per iteration on my PC and 0.008 second per iteration on my Mac.
Now you know!
markER7TS
Maybe you could have the best of both worlds if you modulo divide your operation count and only update the UI every few thousand loops?
jackie.lin.945
Thank you for the information.
