Creating rigid groups from sub-components using the API
bungledb
bungledb
Hi, Folks.
I'm struggling to wrap my head around operations with components that are children of components. Specifically, in this case, I want to make a rigid joint between two subcomponents from different parents.
Following this example, I can create a rigid group from components in the root component with no problem.
I can get it to work if things are all in the root and there are no sub-components involved:
root
+-comp1
+-subcomp1
+-comp2
--subcomp2
But it fails if I put the subcomponents one or more layers deeper, like this:
root
+ comp1
|   -subcomp1
- comp2
    -subcomp2
subcomp1 and subcomp2 are actually other models inserted into this one.
So this works:
import adsk.core, adsk.fusion, adsk.cam, traceback
def run(context):
    #Get system objects
    app = adsk.core.Application.get()
    project = app.data.activeProject
    design = adsk.fusion.Design.cast(app.activeProduct)
    root = design.rootComponent
    trans = adsk.core.Matrix3D.create()
    #Create top level components
    occ = root.occurrences.addNewComponent(trans)
    comp1 = occ.component
    comp1.name = 'comp1'
    comp2 = occ.component
    comp2.name = 'comp2'
    # Get folder containing other models
    for folder in project.rootFolder.dataFolders:
        if folder.name == "ExtComps":
            ext_folder = folder
    # Import each of the other models.
    for file in ext_folder.dataFiles:
        if file.name == 'Sphere':
            file_to_insert = file
            sub_comp1 = root.occurrences.addByInsert(file_to_insert, trans, True)
        elif file.name == 'Cube':
            sub_comp2 = root.occurrences.addByInsert(file_to_insert, trans, True)
    #Create a collection
    occs = adsk.core.ObjectCollection.create()
    occs.add(sub_comp1)
    occs.add(sub_comp2)
    #Create a rigid group.
    isIncludeChildren = True
    rigidGroups_ = root.rigidGroups
    rigidGroups_.add(occs, isIncludeChildren)
But this fails:
def run(context):
    #Get system objects
            ext_folder = folder
            sub_comp1 = comp1.occurrences.addByInsert(file_to_insert, trans, True)
            sub_comp2 = comp2.occurrences.addByInsert(file_to_insert, trans, True)
    occs.add(sub_comp1)
    occs.add(sub_comp2)
-> "RuntimeError: 5 : Provided input paths or alignments are not valid."
It inserts the external files just fine, but hits a wall when I try to create the rigid group. It also fails if I put both of the external objects under the same parent (eg comp1).
It's frustrating, because I can make exactly that rigid group using the GUI with no issues, so it's an allowed action, but I just can't see what I need to do in the API to achieve the same result.
Can anyone tell me what I've missed?
kgrunawalt
To make the joint, you need two components that have full paths from root to component as context. I think the problem is that the two subcomponent objects are lacking that root-based occurrence path context.
I need to brush up on the api to be more specific!
bungledb
Thanks, that helps. So I want to conceptually say "root/comp1/subcomp1," but my understanding of how to work contexts is shaky to say the least. 😕
Reading the docs again, it kind of feels like I should maybe use proxies - something like:
sc1proxy = sub_comp1.createForAssemblyContext(root)
sc2proxy = sub_comp2.createForAssemblyContext(root)
occs.add(sc1proxy)
occs.add(sc2proxy)
but that throws a Type Error of course because I need to put something more than the bare root component in createForAssembly(). Trouble is, I can't figure out what.
BrianEkins
You're very close.  Here's a slightly modified version of your program that works.
def run(context):
    #Get system objects
    occ1 = root.occurrences.addNewComponent(trans)
    comp1 = occ1.component
    occ2 = root.occurrences.addNewComponent(trans)
    comp2 = occ2.component
            ext_folder = folder
    # Import each of the other models. Because these are being created in the
    # context of the components, the occurrences returned are also in that context.
    # This then creates proxies for the occurrences that are relative to root.
            sub_occ1 = comp1.occurrences.addByInsert(file_to_insert, trans, True)
            sub_occ1 = sub_occ1.createForAssemblyContext(occ1)
            sub_occ2 = comp2.occurrences.addByInsert(file_to_insert, trans, True)
            sub_occ2 = sub_occ2.createForAssemblyContext(occ2)
    occs.add(sub_occ1)
    occs.add(sub_occ2)
Brian Ekins
bungledb
Aaahh! The light bulb just came on over my head.
Thank you so much, @BrianEkins, that's great.
