Unable to delete multiple sub assembly (occurences) under the top node (root component)
seb.quevillon.1
Message 1 of 9
seb.quevillon.1
The code below is supposed to delete every single occurrence (sub assembly) under the top node (root Component) that contain 'MALE' or 'FEMALE' in their name. When I run the script, I get an error message (see error message below). Can you please let me know what is the best way to do it.
ERROR MESSAGE :
Design:
Code:
import adsk.core, adsk.fusion, adsk.cam, traceback
def run(context):
    ui = None
    try:
        app = adsk.core.Application.get()
        ui  = app.userInterface
        product = app.activeProduct
        design = adsk.fusion.Design.cast(product)
        rootComp = design.rootComponent
        occs = rootComp.occurrences
        for occ in occs:
            occName = occ.name
            occName = occName.upper()
            if occName.find('MALE') != -1 or occName.find('FEMALE') != -1:
                occ.deleteMe()
    except:
        if ui:
            ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
Replies (8)
Message 2 of 9
seb.quevillon.1
@BrianEkins , can you please take a look
Message 3 of 9
j.han97
Hi @seb.quevillon.1 ,
Try replacing this line
by this
occs = list(rootComp.occurrences)
Message 4 of 9
tykapl.breuil
As @seb.quevillon.1 mentionned, you need to make a copy of the occurences list because when you are iterating through rootComp.occurences deleting an occurence changes the object you are iterating through.
To be clear : imagine you have two occurences that you both want to delete, you start iterating and delete the first one. Then the API checks to see if there is a second occurence to keep iterating but since the first occurence was deleted, the second occurence has become the first and there are no more occurences to iterate through and the program stops.
However I do not get an error message either way so if that doesn't solve your problem I invite you to give us an f3d displaying the problem so we can more effectively help you.
Message 5 of 9
seb.quevillon.1
Hi @tykapl.breuil  and @j.han97 , I modified the code but I still get a bug. As requested, I attached the f3d file and also a video. Thank you for your help.
Message 6 of 9
tykapl.breuil
It seems there are problems with the fact that the component are linked and also a problem with test Male v1:1.
With the ui I can't even manage to remove the latter and the former causes problem when trying to break the links with the API.
I had tried adding :
if occ.isReferencedComponent:
    occ.breakLink()
Message 7 of 9
seb.quevillon.1
Thank you for investigating, any idea how i can fix it ?
Message 8 of 9
BrianEkins
I've spent some time looking at this and have come to two conclusions.
First, there appears to be a bug when deleting occurrences that are an external reference using the API.
Second, the assembly you provided is somehow corrupt. I suspect it's a result of using the API on it and that causing problems.
I created a new top-level assembly using the subassemblies and parts you had. It has less problems and when deleting the occurrences the API calls all succeed but the result isn't correct. The timeline looks good and the nodes representing the occurrences are no longer there but the occurrences still show up in the graphics and in the browser. That's wrong and something that needs to be fixed. If I added a line to first break the link so it's now a local assembly, then everything works as expected.
Here's my slightly modified code and the new assembly.
def run(context):
    ui = None
    try:
        occs = rootComp.occurrences.asArray()
        occ: adsk.fusion.Occurrence
        for occ in occs:
            occName = occ.name
                if occ.isVisible:
                    #occ.breakLink()
                    occ.deleteMe()
    except:
        if ui:
Until this is fixed, I think the best you can do is start with a good assembly and use the breakLink before deleting.
Brian Ekins
Message 9 of 9
seb.quevillon.1
Thank you it works however it takes a really long time to break the links. Using the API, is it possible to insert an existing component from the current project without having it linked ?
