Create surface from equation
I am not sure if it is possible, but if it is it will make my design process much more streamed lined. The issue I have is that I want to create an object in Fusion 360 from a set of equations. It seams like creating a script is the right way to go. So my question is if anyone has crated an object or surface in Fusion 360 from a set of equation that describe the a surface.
BrianEkins
This blog post might help.  It's creating a curve using an equation.  To create a surface you would need to create a series of curves using your equations and then loft through those.
https://ekinssolutions.com/creating-equation-curves-in-fusion-360/
Brian Ekins
Inventor and Fusion 360 API Expert
Website/Blog: https://EkinsSolutions.com
