Subprocess - Windows
MichaelT_123
Advisor Advisor
MichaelT_123
Hi TF360,
It has just happened...
"...\AppData\Local\Autodesk\webdeploy\production\2....dc77\Python\lib\subprocess.py"
has started generating the error:
OSError: [WinError 6] The handle is invalid
The underlying subprocess code has worked perfectly for a long time, and it is so simple that it can not be wrong! It still operates outside F360 environ as it should.
Something has happened in not too distant past (~24h)… sneaky MS update…?
Sincerely
MichaelT
MichaelT
kandennti
I have experience creating scripts using Subprocess.
https://forums.autodesk.com/t5/fusion-360-ri-ben-yu/3dcad-zhong-jianfairuno3dna-dian-qu-xianwoinpoto...
It is running without problems.
In the past, when Fusion360 Update was executed, there was an experience that what was processed correctly resulted in an error.
After completing the update, restart Fusion360 and try to execute the script (add-in) again.
MichaelT_123
Thank you Kandennti-san,
I have closed the gap of understanding the issue to the stage that the subprocess runs as it should now.
The culprit was a bug in Python implementation which sneaked to my PC while I was sleeping,.. sometime during the last ~48 hours.
This ‘fresh’ bug was reported on Python site under the title:
“subprocess.Popen._cleanup() "The handle is invalid" error when some old process is gone”
Ref: https://bugs.python.org/issue37380
Including one of:
stdin=subprocess.DEVNULL
stdin=subprocess.PIPE
as Popen argument fixed (by-passed) the bug.
With Regards
MichaelT
MichaelT
kandennti
