Create a setup with selected Body or Component
j_zander
j_zander
Hi! In my daily workflow i have to create a lot of setups, so I'd like to make this a little bit faster by creating a script. But i'm struggeling getting my selected Body as setup.models and my Component Fixtures as setup.fixtures. Everything else is working as it is supposed to be.
I hope anybody can help me.
import adsk.core, adsk.fusion, adsk.cam, traceback
import os
from enum import Enum
def run(context):
    ui = None
    try:
        app = adsk.core.Application.get()
        ui  = app.userInterface
        product = app.activeProduct
        design = adsk.fusion.Design.cast(product)
            # use existing document, load 2D Strategies model from the Fusion CAM Samples folder
        doc = app.activeDocument
        #Start AutoSetup
        ui.messageBox('Start AutoSetup')
        # Select Part
        # Select Part
        ui.messageBox('Select Part')
        selectedEntity = ui.selectEntity('Select the part to machine', 'Bodies')
        # Überprüfen, ob ein Körper ausgewählt wurde
        if selectedEntity is None:
            ui.messageBox('Kein Körper ausgewählt. Das Skript wird beendet.')
            return
        ui.messageBox('Part Selected')
        #WCS
        WCS = design.userParameters.itemByName('wcs').expression
        ui.messageBox('WCS {} is selected'.format(WCS))
         # switch to manufacturing space
        camWS = ui.workspaces.itemById('CAMEnvironment')
        camWS.activate()
        # get the CAM product
        products = doc.products
       #################### create setup ####################
        cam = adsk.cam.CAM.cast(products.itemByProductType("CAMProductType"))
        setups = cam.setups
        setupInput = setups.createInput(adsk.cam.OperationTypes.MillingOperation)
        # This part is not working !
        models = adsk.core.ObjectCollection.create()
        models.add(selectedEntity[0])
        setupInput.models = models
        # create the setup
        setup = setups.add(setupInput)
        docname = app.activeDocument.name
        setup.name = docname
        setup.fixtureEnabled = True
        programNameParam = setup.parameters.itemByName('job_programName')
        programNameParam.expression = "'{}'".format(docname)
        programWorkoffsetParam = setup.parameters.itemByName('job_workOffset')
        programWorkoffsetParam.expression = WCS
    except:
        if ui:
            ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
kandennti
Hi @j_zander -San.
The most likely reason is that you are using an ObjectCollection object.
You can set it up using a list.
I was also able to set the fixtures using cam.SetupInput.
The following sample was tested with the attached f3d.
# Fusion360API Python script
import traceback
import adsk.core as core
import adsk.fusion as fusion
import adsk.cam as cam
def run(context):
    ui: core.UserInterface = None
    try:
        app: core.Application = core.Application.get()
        camObj: cam.CAM = get_cam_product()
        rootOcc: fusion.Occurrence = camObj.designRootOccurrence
        root: fusion.Component = rootOcc.component
        setup: cam.Setup = create_setup(
            camObj,
            root.bRepBodies[0],
            root.allOccurrences[0]
        ui.messageBox("Done")
    except:
        if ui:
def create_setup(
    camObj: cam.CAM,
    targetBody: fusion.BRepBody,
    fixture: core.Base,
    ) -> cam.Setup:
    setups: cam.Setups = camObj.setups
    setupIpt: cam.SetupInput = setups.createInput(
    setupIpt.models = [targetBody]
    setupIpt.fixtures = [fixture]
    setup: cam.Setup = setups.add(setupIpt)
    return setup
def get_cam_product() -> cam.CAM:
    activete_cam_env()
    return app.activeProduct
def activete_cam_env() -> None:
    ui: core.UserInterface = app.userInterface
    camWS: core.Workspace = ui.workspaces.itemById('CAMEnvironment')
    camWS.activate()
The result looks like this
j_zander
Thanks for your help. The Solution is ok but in your script the setupmodel has to be  a body and can't be a component. And in my project Fixture is a vise with a few components. The script just adds the first component of the fixture components. Also the script uses the first component it's finding. In my case it is the stockmodel i use to position my parts inside my vise. This should be ignored.
Is it possible to Select a whole component by name with everything inside of it? Then i just could put my body that should be machined inside of the targetBodyComponent and its automatically selectet.
I attach my fixture file here. Thanks for your help 🙂
kandennti
@j_zander -San.
I may not be understanding what you mean.
Do you mean like this?
import traceback
def run(context):
    try:
        # models
        modelsOcc: fusion.Occurrence = root.allOccurrences.itemByName("targetBody:1")
        if not modelsOcc: return
        # fixtures:
        fixturesOcc: fusion.Occurrence = root.allOccurrences.itemByName("Fixture:1")
        if not fixturesOcc: return
            camObj,
            [modelsOcc],
            [fixturesOcc],
    except:
        if ui:
def create_setup(
    camObj: cam.CAM,
    models: list[core.Base],
    fixtures: list[core.Base],
    ) -> cam.Setup:
    setupIpt.models = models
    setupIpt.fixtures = fixtures
    return setup
    activete_cam_env()
    camWS.activate()
j_zander
Perfect! That's exactly what i wanted! Thank you very much!
