Component Transform Rotates Correctly but Moves Incorrectly
ebunn3
ebunn3
Been wheel spinning for hours on this.  I have inserted some code below that is supposed to rotate an occurrence, followed by moving it a specific distance.  The rotation works but the move does not work.  Its supposed to rotate it 90 degrees and then move it 1 inch in the X direction.  It ends up being moved in both x and y by unknown distances.  Can anyone help with this.  I'm sure I am doing something fundamentally wrong.
Eric
def rotateMoveComp(comp,angleDeg,x,y,z):
    ui = None
    try:
        app = adsk.core.Application.get()
        ui  = app.userInterface
        product = app.activeProduct
        design = adsk.fusion.Design.cast(product)
        if not design:
            ui.messageBox('No active Fusion design', 'No Design')
            return
        # Get the root component
        rootComp = design.rootComponent
        #get bounding box min
        bbMin = comp.boundingBox.minPoint
        # get Occurrence transform
        mat: adsk.core.Matrix3D = comp.transform
        import math
        mat.setToRotation(math.radians(angleDeg), adsk.core.Vector3D.create(0,0,1), bbMin)
        # set transform
        comp.transform = mat
        vector = adsk.core.Vector3D.create(x, y, z)
        # Matrix translation
        mat.translation = vector
        # set transform
        print('')
    except:
        if ui:
            ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
sel = ui.selectEntity('Choose Cushion Component', 'Occurrences')
cushion = adsk.fusion.Occurrence.cast(sel.entity)
rotateMoveComp(cushion,90,1*2.54,0,0)
ebunn3
I believe I solved this using the following line of code for creation of the translation vector:
# Create vector
        vector = adsk.core.Vector3D.create(mat.translation.x+x, mat.translation.y+y, mat.translation.z+z)
This would replace line 28 below.
Eric
Jorge_Jaramillo
hi @ebunn3 ,
It is better to make a matrix multiplication to get the translation once you had rotated the component.
So you multiply the rotated matrix by a translation matrix.
This is how you can implement it:
        # import math
        # set transform
        app.log(f'mat transform rotate 90: {mat.asArray()}')
        mat_translate = adsk.core.Matrix3D.create()
        mat_translate.translation = vector
        mat.transformBy(mat_translate)
        # set transform
        app.log(f'resulting matrix: {mat.asArray()}')
You could check that the only value that changes is the fourth value of the matrix, which corresponds to the X displacement.
Hope this help.
Jorge
