No prompt for origin construction plane?
andy.d.doyle
Observer Observer
andy.d.doyle
Observer
Observer
Hey guys, super new to writing scripts/add-ins!
I've created SelectionCommandInput to choose which plane to sketch stuff on. I'd like to show the origin construction planes, but can't seem to figure it out.
I can choose a default construction plane just fine:
        # Construction pane selection
        construction_plane_input = inputs.addSelectionInput('plane', 'Construction Plane', 'Select a Construction Plane')
        construction_plane_input.addSelectionFilter(adsk.core.SelectionCommandInput.ConstructionPlanes)
        construction_plane_input.addSelection(design.rootComponent.xYConstructionPlane)
I'd like to show the origin planes (XY, XZ, YZ) as options similar to creating a new sketch. Something like this:
I started going down this path, but this doesn't work at all.
def input_changed_handler(args: adsk.core.InputChangedEventArgs):
    # Show construction plane input as necessary
    if args.input.id == 'plane_input':
        plane_input: adsk.core.SelectionCommandInput = args.inputs.itemById('plane_input')
        design = adsk.fusion.Design.cast(app.activeProduct)
        root = design.rootComponent
        # Show construction plane picker
        # THIS DID NOT WORK
        if not plane_input.selectionCount:
            input: adsk.fusion.ConstructionPlaneInput = root.constructionPlanes.createInput(design.activeOccurrence)
            root.constructionPlanes.add(input)
Any help at all would be greatly appreciated!
Thanks!
kandennti
Hi @andy.d.doyle .
I may not have understood the question.
If you are saying that the origin is not displayed, then set the Component.isOriginFolderLightBulbOn property to True.
# Fusion360API Python script
import traceback
import adsk.fusion
import adsk.core
def run(context):
    ui = adsk.core.UserInterface.cast(None)
    try:
        app: adsk.core.Application = adsk.core.Application.get()
        ui = app.userInterface
        app.documents.add(adsk.core.DocumentTypes.FusionDesignDocumentType)
        des: adsk.fusion.Design = app.activeProduct
        root: adsk.fusion.Component = des.rootComponent
        root.isOriginFolderLightBulbOn = True
        msg: str = 'Select Construction Plane'
        selFilter: str = 'ConstructionPlanes'
        sel: adsk.core.Selection = selectEnt(msg, selFilter)
        root.isOriginFolderLightBulbOn = False
        if not sel:
            return
        root.sketches.add(
            sel.entity
        ui.messageBox('Done')
    except:
        if ui:
            ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
def selectEnt(
        msg: str,
        filterStr: str) -> adsk.core.Selection:
    try:
        ui: adsk.core.UserInterface = app.userInterface
        sel = ui.selectEntity(msg, filterStr)
        return sel
    except:
        return None
Or are you saying that input_changed_handler is not being called?
andy.d.doyle
Observer
Observer
Hey! Thanks for the reply. That seems to work in the general sense, but I must be getting my event stack ordering messed up or something. I'm trying to show the origin planes when I clear the input, and then hide it when something gets selected.
However doing this in the input_changed_handler doesn't seem to be getting the behavior I'm after.
    if args.input.id == 'plane':
        # Show/hide construction plane picker
        if (plane_input.selectionCount == 0):
            log('turning on the origin')
        else:
            log('turning off the origin')
 If you don't mind taking a look, I have my code up on GitHub, handlers/input_changed_handler.py
kandennti
@andy.d.doyle .
Thanks for making this public.
I would like to try it out, but I am not sure of the format of the csv file.
Could you provide a sample csv file?
kandennti
@andy.d.doyle .
I understood one thing.
Not only do the events fire at different times, but they are limited in what they can do.
The CommandDefinition.commandCreated event is particularly special.
My impression is that the command itself is not created until the CommandCreated event ends.
Therefore, you are trying to have the XYPlane selected first, and that is the reason why it is not selected successfully.
If you want it to be selected when the dialog appears, then let it be selected at the time of the Command.activate event.
https://help.autodesk.com/view/fusion360/ENU/?guid=GUID-eeb18ad8-6ea6-4a35-923f-c96113549704
I sense other problems, but it is not immediately clear what the cause is, since it is obvious that there is a bug in the current version of SelectionCommandInput.
I am attaching only the created_handler.py with the fixes, just in case.
kandennti
@andy.d.doyle .
I found out one more thing.
I had my doubts about not being able to reselect planes.
I made a few changes to your input_changed_handler and confirmed that the SelectionCommandInput is deselected when the isOriginFolderLightBulbOn property is changed.
Perhaps this is a specification of the Fusion360 API. It should not have been allowed to manipulate the document within the event handler.
So unfortunately, the processing you want is not possible.
I have attached the input_changed_handler.py I used for confirmation, just in case.
You do not need to provide the csv file.
pieterparker60
Community Visitor
Community Visitor
This is a great information, really helpful. I recently made a plane by using powerful construction tools from valveswood.com.
