component.flatPattern.flatBody.material.name / RuntimeError: 2 : InternalValidationError : assetInst
gvisca44
gvisca44
Struggling to find why I'm receiving this error ... other than it's a bug-but I will be happily corrected.
Code objective is to extract a bunch of information from sheet metal components so I can create purchase orders in my financial system automatically.
I have chosen to use the material object from component.flatPattern.flatBody to avoid "challenges" where a sheet metal component has become "an assembly" and has downstream components (for example - press fit clinch studs/nuts).
Note -
(1) - I experienced the error on component "No folds" (note the lower case 'f').
(2) - some components use materials from my private material library and I am not sure what happens with them when the f3z archive is created.
Code as follows:
import adsk.core
import adsk.fusion
import traceback
def run(context):
    ui = None
    try:
        app = adsk.core.Application.get()
        ui  = app.userInterface
        product = app.activeProduct
        design = adsk.fusion.Design.cast(product)
        if not design:
            ui.messageBox('No active Fusion design', 'No Design')
            return
        allComps: adsk.fusion.Components = design.allComponents
        for component in allComps:
            processComponent = False
            for body in component.bRepBodies:
                if body.isSheetMetal:
                    msg = f'Component \t "{component.name}" has sheet metal body'
                    app.log(msg)
                    adsk.doEvents()
                    if not component.flatPattern:
                        msg = f'\tNo flat pattern exists'
                        app.log(msg)
                    else:
                        msg = f'\tFlat pattern name = "{component.flatPattern.name}" '
                        app.log(msg)
                        flatPatternHealth = component.flatPattern.healthState
                        # REFER ENUMS to evaluate this.
                        if flatPatternHealth == adsk.fusion.FeatureHealthStates.HealthyFeatureHealthState:
                            msg = f'\tComponent will be processed'
                            app.log(msg)
                            processComponent = True
                    bendLinesBody = component.flatPattern.bendLinesBody
                    for BRepEdge in bendLinesBody.edges:
                        (retval, isBendUp, bendAngle) = component.flatPattern.getBendInfo(BRepEdge)
                        msg = f'\tretval:{retval} isBendUp:{isBendUp} bendAngle:{bendAngle}'
                        app.log(msg)
                        adsk.doEvents()
            if processComponent == True:
                if not component.material:
                    mat = 'No Material'
                else:
                    mat = component.material.name
                thickness = component.activeSheetMetalRule.thickness.value
                matCode = f'mat_{mat} t={thickness * 10:.1f}'
                msg = f'\tMaterial code(1): {matCode}'
                app.log(msg)
                adsk.doEvents()
                matObjType = component.flatPattern.flatBody.material.objectType
                msg = f'\tFlat Pattern Material object type: {matObjType}'
                app.log(msg)
                adsk.doEvents()
                mat = component.flatPattern.flatBody.material.name
                msg = f'\tMaterial code(2): {matCode}'
                app.log(msg)
                adsk.doEvents()
    except:
        if ui:
            app.log(f'Failed:\n{ format(traceback.format_exc()) }')
            #ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
Error
Traceback (most recent call last):
  File "D:/Users/Public/G2VDesign_OneDrive/OneDrive - G2V DESIGN PTY LTD/Fusion 360 Tools/Add-ins/$GV Test Bed/$GV Test Bed.py", line 69, in run
  File "C:\Users/gvisc/AppData/Local/Autodesk/webdeploy/production/414da7cdec4faa7986fe0d205fb521fc68f5d46c/Api/Python/packages\adsk\core.py", line 11404, in _get_name
    return _core.Material__get_name(self)
Glenn.
sanjana.shankar.goli
Autodesk Support
Autodesk Support
@kandennti would you be able to share your insights here? Thank you!
Sanjana Goli
Software QA Engineer
Fusion 360 Webinars | Tips and Best Practices | Troubleshooting
boopathi.sivakumar
Hi @gvisca44
Could not able to reproduce this error
I got the complete result with your attached model
Since the error happens at this line I would assume this because the
since the material property will be only valid if the flatBody is not transient so it is better to put a check if the body is not transient
https://help.autodesk.com/view/fusion360/ENU/?guid=GUID-323AC688-6E8C-45B3-8D65-421D618FE87D
Boopathi Sivakumar
Senior Technology Consultant
gvisca44
Thanks for looking at this @boopathi.sivakumar.  Please go ahead and close the case.
It seems the error may have been fixed since I originally posted.
Can you explain the isTransient property ?
What would make a bRepBody - well - flat pattern body - transient ?
Glenn.
