Spline Constraint
Spline Constraint
dozerdroid
Spline Constraint
dozerdroid
Hi, I have been creating splines for hull section shapes as below
And it's working fine except I need a horizontal constraint at the bottom of the hull, if I manually click and add the constraint it works fine as shown below
But of course I need to do this programatically .. so I have been experimenting like below
constraints = sketch.geometricConstraints
constraints.addHorizontalPoints(point)
but i can't seem to make it work ? if you have any pointers or suggestions it would be most appreciated, thx Khim
BrianEkins
The constraint is added to a line that controls the tangent at that fit point. It's possible to do that through the API too. Here's some code that demonstrates creating a spline, getting the line that controls the tangent at the start of the spline and adding the horizontal constraint.
sk: adsk.fusion.Sketch = root.sketches.add(root.xYConstructionPlane)
points = adsk.core.ObjectCollection.create()
points.add(adsk.core.Point3D.create(0, 0, 0))
points.add(adsk.core.Point3D.create(5, 2, 0))
points.add(adsk.core.Point3D.create(8, 5, 0))
points.add(adsk.core.Point3D.create(12, 2, 0))
points.add(adsk.core.Point3D.create(18, 5, 0))
spline = sk.sketchCurves.sketchFittedSplines.add(points)
tanLine = spline.activateTangentHandle(spline.startSketchPoint)
sk.geometricConstraints.addHorizontal(tanLine)
Brian Ekins
dozerdroid
Ths for the help, Khim
