Code with global variables
Peter__B
Peter__B
Hi
The following code has been written just for my own education and understandig and does not generate anything of value.
However, does anybody know why the code does not print 'newstring' to the spyder console window ? Instead it prints 'string', what commands do I have to add to the code in order get the 'newstring' to the console window. I have tried with global variables without success.
Best Regards
Peter
Peter__B
Sorry I forgot the code:
import adsk.core, adsk.fusion, adsk.cam, traceback
text='string'
def run(context):
ui = None
try:
app = adsk.core.Application.get()
ui = app.userInterface
# ui.messageBox('Hello script')
product = app.activeProduct
design = adsk.fusion.Design.cast(product)
global trt
text='newstring'
rootComp = design.rootComponent
sketches = rootComp.sketches
xyPlane = rootComp.xYConstructionPlane
sketch = sketches.add(xyPlane)
sketch.name = 'FirstComponent'
xzPlane = rootComp.xZConstructionPlane
sketch = sketches.add(xzPlane)
sketch.name = 'SecondComponent'
exportMgr = design.exportManager
fusionExportOptions = exportMgr.\
createFusionArchiveExportOptions('D:/FusionData/CadTest')
exportMgr.execute(fusionExportOptions)
return text
except:
if ui:
ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
print(text)
/Peter
Peter__B
The formatting disappeared, here is the code aqain;
#Author-
#Description-
text='string'
def run(context):
    ui = None
    try:
        global trt
        text='newstring'
        return text
    except:
        if ui:
print(text)
The error is due to the nature of python. Your print statement is outside the body of the run method. When python loads a source file it executes it. When the file is executed the text='string' code is evaluated, the "def" statement is evaluated and the "run" method is created (in python methods ARE objects too!), then your print(text) statement is executed, and the execution of the file completes (without ever executing the contents of the run method. Then some time later the python layer inside Fusion looks for and finds a method with the name of "run" and executes it.
So the problem is the contents of your run method are NOT executed before your print statement. I hope this helps - if not the internet can do a better job of explaining things than I have I'm sure.
