API To Get Material Type
isocam
isocam
Can anybody help?
Does anybody know how to display (in a message box for testing only) the Fusion 360 part material?
Say I have a part and I assign Stainless Steel to that part, I need to be able to display the material in a message box.
This is just a small part of a larger project that I an working on.
Many thanks in advance!!!!
Darren
erik
I am not entirely sure what you want, but if it is the name of the material applied to a component its usually the same as the appearance name which can be found using the following code
appearanceName = occurrence.appearance.name
and displayed using the following code
app = adsk.core.Application.get()
ui  = app.userInterface
ui.messageBox(appearanceName)
Please reply if this is what you want or something else is desired? 🙂
- Erik
wegienka
Given a component in:
Ptr<Component> comp;
You can access the material properties using:
Ptr<Material> mat = comp->material();
string matname = mat->name();
