Adding information 'i' button to Addin command input dialog
balunist
balunist
All the Fusion command input dialogs have this information 'i' button defined.  Is there an example of how this could be done with an addin.  I would assume that it involves access the toolbar which contains the OK and Cancel but I could use a pointer on how to do that.
Thanks in advance!
Be aware that the Fusion API is completely separate from the way Fusion developers create commands.
That said, I swear I've seen how to make that icon work... I think I found what you are looking for - see "helpFile" in this topic
balunist
Thanks Ross.  I missed that.   Yes and I understand the AddIn API is a restricted subset which is necessary otherwise the product evolution could be hampered.
Happy New Years!  Bill
