Choose material from Favorites
Darren_Fisher
Darren_Fisher
I trying to pick a material stored in my 'Favorites' and assign to a body but get the error shown in the pic.
I've used the following code, and worked fine when picking from the 'Fusion 360 Material Library'
# get material lib
mLibs = app.materialLibraries
mLib = mLibs.itemByName('Favorites')
# get one material from this lib
mOne = mLib.materials.itemByName('AB2')
BladeLoftBody = BladeLoft.bodies.item(0)
bodyM = BladeLoftBody.material
# change body material
BladeLoftBody.material = mOne
app.activeViewport.refresh()
Many Thanks in advance.
Error and material shown in FavoritesError and material shown in Favorites
JeromeBriot
the error message says that the object mLib is empty (None). You should always test the returned value when accessing an item of a collections. For example:
import adsk.core, traceback
def run(context):
    ui = None
    try:
        app = adsk.core.Application.get()
        ui  = app.userInterface
        materialLibrary = 'Favorite'
        mLib = mLibs.itemByName(materialLibrary)
        if mLib is None:
            ui.messageBox('Material "{}" not found.'.format(materialLibrary))
            return
    except:
        if ui:
            ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
To solve your problem, replace:
with:
mLib = mLibs.itemByName('Favorites Library')
Here is a code to list all material libraries by name:
def run(context):
    ui = None
    try:
        for mLib in mLibs:
            print(mLib.name)
    except:
        if ui:
You can use the same approach with any collections when you need to get a specific item by name.
Hope this helps
Darren_Fisher
Fantastic thanks for the help, its working perfectly now.
Just starting out in the API area so will no doupt have many more questions.
