[Bug] Modify a sketchText with an empty string gives weird result
JeromeBriot
Mentor Mentor
Message 1 of 1
JeromeBriot
Here is a script that creates a sketchText object with an empty string (i.e. ''). Then it modifies the text inside the object.
import adsk.core, traceback # pylint: disable=import-error
import math
def run(context):
    ui = None
    try:
        app = adsk.core.Application.get()
        ui  = app.userInterface
        design = app.activeProduct
        rootComp = design.rootComponent
        sketches = rootComp.sketches
        xyPlane = rootComp.xYConstructionPlane
        sketch = sketches.add(xyPlane)
        sketchTexts = sketch.sketchTexts
        sketchTextInput = sketchTexts.createInput('', 1.0, adsk.core.Point3D.create(1.0, 1.0, 1.0))
        sketchText = sketchTexts.add(sketchTextInput)
        sketchText.text = 'example'
    except:
        if ui:
            ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
Here is the result:
And when editing the sketch :
The height of the text should be 10mm but it is 38.344mm
Thank you
Replies (0)
