[Bug] Create a SketchText with negative angle returns "invalid input angle"
JeromeBriot
Mentor Mentor
Message 1 of 1
JeromeBriot
Here is an example that should create a text rotated by -90° in a sketch:
import adsk.core, traceback # pylint: disable=import-error
import math
def run(context):
    ui = None
    try:
        app = adsk.core.Application.get()
        ui  = app.userInterface
        design = app.activeProduct
        rootComp = design.rootComponent
        sketches = rootComp.sketches
        xyPlane = rootComp.xYConstructionPlane
        sketch = sketches.add(xyPlane)
        sketchTexts = sketch.sketchTexts
        sketchTextInput = sketchTexts.createInput('example', 1.0, adsk.core.Point3D.create(1.0, 1.0, 1.0))
        sketchTextInput.angle = -math.pi / 2
        sketchText = sketchTexts.add(sketchTextInput)
    except:
        if ui:
            ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
The code fails by returning the error "invalid input angle".
The documentation of the angle property should also mention that the value must be in radian and not in degree.
This is not obvious because it's the opposite in the dialog in Fusion 360.
Thank you.
Replies (0)
