Appearance Bug??
Appearance Bug??
brad.bylls
Appearance Bug??
brad.bylls
I have some code from an add-in I'm working on that worked several months ago.
    # Set the spring color
    fusionMaterials = _app.materialLibraries.itemByName('Fusion 360 Appearance Library')
    appear = fusionMaterials.appearances.itemByName('Powder Coat (Blue)')
    if strColor == 'Blue':
        blueColor = design.appearances.addByCopy(appear'BlueColor')  <<< Line 290
        colorProp = adsk.core.ColorProperty.cast(blueColor.appearanceProperties.itemByName('Color'))
        colorProp.value = adsk.core.Color.create(002550)
        bd.appearance = blueColor
    elif strColor == 'Red':
        redColor = design.appearances.addByCopy(appear'RedColor')
        colorProp = adsk.core.ColorProperty.cast(redColor.appearanceProperties.itemByName('Color'))
        colorProp.value = adsk.core.Color.create(255000)
        bd.appearance = redColor
    elif strColor == 'Gold':
        goldColor = design.appearances.addByCopy(appear'GoldColor')
        colorProp = adsk.core.ColorProperty.cast(goldColor.appearanceProperties.itemByName('Color'))
        colorProp.value = adsk.core.Color.create(20420400)
        bd.appearance = goldColor
    else:
        greenColor = design.appearances.addByCopy(appear'GreenColor')
        colorProp = adsk.core.ColorProperty.cast(greenColor.appearanceProperties.itemByName('Color'))
        colorProp.value = adsk.core.Color.create(015300)
        bd.appearance = greenColor
I am now revising the code and I get this error message:
Has something changed in the API or is it my code?
Thanks in advance for any help.
Brad Bylls
kandennti
Hi @brad.bylls .
Isn't there already an appearance with the same name ('BlueColor') in design.apppearances?
brad.bylls
kandennti,
I only know of this:
I will change the name to BluColor and see what happens.
Thanks.
Brad Bylls
brad.bylls
Thanks kandennti.
That worked.
Just strange that it worked before and not now.
Brad Bylls
brad.bylls
Okay.
I changed the names of the colors.
    if strColr == 'Blue':
        blueColr = design.appearances.addByCopy(appear'BlueColr')
        colorProp = adsk.core.ColorProperty.cast(blueColr.appearanceProperties.itemByName('Color'))
        bd.appearance = blueColr
    elif strColr == 'Red':
        redColr = design.appearances.addByCopy(appear'RedColr')
        colorProp = adsk.core.ColorProperty.cast(redColr.appearanceProperties.itemByName('Color'))
        bd.appearance = redColr
    elif strColr == 'Gold':
        goldColr = design.appearances.addByCopy(appear'GoldColr')
        colorProp = adsk.core.ColorProperty.cast(goldColr.appearanceProperties.itemByName('Color'))
        bd.appearance = goldColr
    else:
        greenColr = design.appearances.addByCopy(appear'GreenColr')
        colorProp = adsk.core.ColorProperty.cast(greenColr.appearanceProperties.itemByName('Color'))
        bd.appearance = greenColr
But then I found out that if I run the add-in script a second time, I get the same message.
I think what I need to do is delete that color at the end of the script so if it runs again I won't get the message.
Do you know how to delete a color?
Thank you.
Brad Bylls
BrianEkins
I did some testing a while ago and found some problems with appearances.  Autodesk is aware of the problems.  So, it may not be your code but a bug you've run into.
Brian Ekins
brad.bylls
Thanks Brian.
Just did some if . . . else to get around the problem.
Brad Bylls
