Access file tree structure.
LiveLover
LiveLover
Hello!
Can we observe projects list and project's directory/file structure?
Thank you!
sasikanth.kollipara
Hi, Thanks for using Fusion. Are you looking for API or a place to view the structure?
You can see it in the web interface as well.
If my post answers your question, please click the "Accept Solution" button. This helps everyone find answers more quickly!
Sas
Sasikanth Kollipara
Product owner and customer support in Fusion
LinkedIn
JeromeBriot
Here is a script that list all hubs, projects, folders and files.
Note that the code takes time to end because it gets the information from the Autodesk server.
import adsk.core, adsk.fusion, traceback
import platform
import os
if platform.system() == 'Windows':
    desktopPath = os.path.join(os.getenv('USERPROFILE'), 'Desktop')
else:
    desktopPath = os.path.join(os.path.expanduser('~'), 'Desktop')
txtFile = os.path.join(desktopPath, 'DataFusion360.txt')
def getFolderData(folder, level, f):
    for dataFile in folder.dataFiles:
        f.write('\n' + '\t'*level + dataFile.name + ' | ' + dataFile.id)
    for dataFolder in folder.dataFolders:
        f.write('\n' + '\t'*level + dataFolder.name + ' | ' + dataFolder.id)
        getFolderData(dataFolder, level+1, f)
def run(context):
    ui = None
    try:
        app = adsk.core.Application.get()
        ui  = app.userInterface
        with open(txtFile, 'w') as f:
            for dataHub in app.data.dataHubs:
                f.write(dataHub.name)
                for dataProject in dataHub.dataProjects:
                    f.write('\n\t' + dataProject.name + ' | ' + dataProject.id)
                    getFolderData(dataProject.rootFolder, 2, f)
                f.write('\n')
        ui.messageBox('End')
    except:
        if ui:
            ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
LiveLover
Hello @sasikanth.kollipara! Thank you for replying!
https://www.autodesk.com/products/fusion-360/collaborator
shows me
is this because I have no some (what?) subscription?
And "ViewDetails on Web" brings me to a web observer for my projects
sasikanth.kollipara
You can click Access now on the above screenshot you shared and you should be able to view the web interface.
And if you have the proper entitlement in Fusion, you are free to use this web interface for all your data management activities.  You can do File operations pretty easy along with the review capabilities.
Sas
Sasikanth Kollipara
LinkedIn
kandennti
Hi @JeromeBriot .
I have made a similar script, but I did not do such detailed information. It's great.
It seems to be slightly faster to use the asArray method.
However, empty folders, etc. caused an error.
Also, I am using it in a Japanese environment, and due to encoding problems, I get an error when writing the file. If you are not an English-speaking user, you may experience the same error.
So, I decode the file before writing it out.
# Fusion360API Python script
import platform
import os
import time
else:
def getFolderData(folder, level, lst):
    try:
        for dataFile in folder.dataFiles.asArray():
            lst.append('\t'*level + dataFile.name + ' | ' + dataFile.id)
    except:
        pass
    try:
        for dataFolder in folder.dataFolders.asArray():
            lst.append('\t'*level + dataFolder.name + ' | ' + dataFolder.id)
            lst = getFolderData(dataFolder, level+1, lst)
    except:
        pass
    return lst
def run(context):
    ui = None
    try:
        t = time.time()
        # get data
        lst =[]
        for dataHub in app.data.dataHubs.asArray():
            lst.append(dataHub.name)
            try:
                for dataProject in dataHub.dataProjects.asArray():
                    lst.append('\t' + dataProject.name + ' | ' + dataProject.id)
                    lst = getFolderData(dataProject.rootFolder, 2, lst)
            except:
                pass
        # write file
            f.write(toDecode('\n'.join(lst)))
        ui.messageBox(f'Done:{time.time()-t}s')
    except:
        if ui:
def toDecode(s):
     return s.encode("CP932", "ignore").decode("CP932")
It is now faster than before, but access to the data hub is still slow.
JeromeBriot
You can also try this :
with open(txtFile, 'w', encoding='cp932') as f:
