Addins Lost recently
davebYYPCU
Consultant Consultant
davebYYPCU
My Addins have been lost or removed, and trying to restore it, fails with this message
The path name in the load instructions are slightly different to real life, I have to select a Roaming Directory to dig deeper and my folder is in this altered Path.
Need some advice how to proceed, please.
BrianEkins
Each script or add-in should exist within a folder. The folder, .py, and .manifest files should all have the same name. The location where Fusion looks for scripts and add-ins is specified in your preferences. The default path is in your local APPDATA path, as illustrated below. I'm guessing that somehow your default path has been changed.
Brian Ekins
davebYYPCU
I was apparently adding a next level of folders, moved all up a level, and that's got this one working, many thanks,
