Not able to use AWS SDK
xusho
Autodesk Autodesk
xusho
I have an AddIn in C++. Installed AWS SDK by vcpkg. When running the AddIn, it is stuck when calling Aws::initAPI().
I have also installed nlohmann to use json in the C++ program, and it has no problems.
Is there any restrictions?
Shoudong Xu
Autodesk Moldflow Meshing
Shoudong.Xu@autodesk.com
BrianEkins
Your add-in is running within the Fusion process. Fusion data is stored on AWS, so there are likely some AWS dependencies in Fusion, and maybe that's causing some conflicts. That's just a guess.
Brian Ekins
