Adding and removing a TabCommandInput on the fly
nraynaud
nraynaud
I am trying to change the UI in reaction to some input change, but it looks like nothing is reacting.
here is a test (using Fusion360AddinSkeleton):
class TestTabCommand(Fusion360CommandBase):
def on_input_changed(self, command: Command, inputs: CommandInputs, changed_input, input_values):
if changed_input.id == 'test':
AppObjects().ui.messageBox('adding tab')
self.inputs.addTabCommandInput('general_tab', 'New Tab', '')
def on_create(self, command: Command, inputs: CommandInputs):
self.inputs = inputs
general_tab = inputs.addTabCommandInput('general_tab', 'General', '')
general_tab.children.addBoolValueInput('test', 'test', False)
 When clicking on the 'test' button, the messageBox shows, but no new tab appears.
Is there a way to customize the UI on the fly?
Thanks for your help,
Nicolas.
nraynaud
