Change select by mouse
-pezi-
-pezi-
I have addIn and if CommandInputs with SelectionCommandInput is active, I can not change the mouse component selection from the tree (Browser). Only when I cancel the current selection can I change the selection. Selections directly in the model space work as expected. Do I make a mistake somewhere, or is it a Fusion property?
My code behaves just like solution:
https://forums.autodesk.com/t5/fusion-360-api-and-scripts/how-to-use-the-selectioneventhandler/m-p/6...
BrianEkins
What type of objects are you filtering for in the SelectionCommandInput?  What's displayed in the browser are occurrences, not components.
Brian Ekins
-pezi-
I have setting Occurrences as type of objects for filtering. Apology, for my bad describe in original question.
BrianEkins
I added the line highlighted below to the command inputs sample and I can select occurrences in both the graphics window and the browser.  Can you double-check your code again?
            # Create a selection input.
            selectionInput = tab1ChildInputs.addSelectionInput('selection', 'Select', 'Basic select command input')
            selectionInput.addSelectionFilter('Occurrences')
            selectionInput.setSelectionLimits(0)
Brian Ekins
-pezi-
Your solution is function for multiSelect, but i need select only one occurrence.
selectionInput.setSelectionLimits(1,1)
