Add-In trouble
Add-In trouble
brad.bylls
Add-In trouble
brad.bylls
I have added a video to explain my problem and the code to go with it.
The code works when I create something in F360 but if I bring in a step file from a website it does not.
Brad Bylls
BrianEkins
I didn't try running your code, but from watching your video, I can see in the first case, the design is set to capture the design history, and in the second case, it is not. In the imported file, right-click on the browser's top node, choose the "Capture Design History" command, and then see if it works.
Brian Ekins
brad.bylls
Thanks Brian.
Adding the design history solved the error problem.
Brad
Brad Bylls
