[Add-In] Check computer specifications
JeromeBriot
Mentor Mentor
JeromeBriot
CheckComputerSpecs is an add-in that checks computer specifications against system requirements recommended by Autodesk for Fusion 360. It works on Windows and macOS.
It scans your computer for information about CPU, GPU and memory modules. Then it compares the values with the tables in the system requirements webpage on the Autodesk website.
Codes and information are posted on GitHub: https://github.com/JeromeBriot/fusion360-check-computer-specifications
Post comments in this discussion. Report bugs on the Issues page of the GitHub repo if possible.
Thank you.
JeromeBriot
New version available (0.2.0):
  • Add tools for debugging
  • Display memory amount in megabytes if less than one gigabyte
  • Fix some typos
You can help to improve this add-in by sending me a file with the specifications of your machine.
Instructions are displayed at the bottom of the palette.
Thank you.
JeromeBriot
New version available (0.3.0):
  • Add support for DDR5 RAM
Thank you.
JeromeBriot
New version available (0.4.0):
  • Fix bug on macOS with M1 chip
Thank you.
