Accessing BRep of existing solids
Is it possible to access BRep of existing solids and build an adjacency matrix to describe the relation between different faces?
I have been trying to use adsk.fusion.BRepBody and adsk.fusion.BRepBodies, but they seam only thought for creating new solids, while I would like to analyse already existing one.
Cheers,
-P-
JesusFreke
You can definitely access the brep of existing objects.
e.g. to access the brep of a body in the root component,
def run(_):
app = adsk.core.Application.get()
ui = app.userInterface
design: adsk.fusion.Design = app.activeProduct
root = design.rootComponent
brep: adsk.fusion.BRepBody = root.bRepBodies[0]
ui.messageBox('Body name: %s' % brep.name)
And of course you can traverse the component/occurrence hierarchy and similarly access any bodies in any sub-components, etc.
