Unable to download render image
Message 1 of 22
I can't download any of my renders and get this message pop up. I have been trying over two days now and on two computers. can someone help me please?
Replies (21)
Message 2 of 22
paul.clauss
Hi @Anonymous
Thanks for posting! I've seen a few reports of this behavior lately - in the threads linked below:
I haven't received any response on the other two threads yet, and would be curious to hear if the issue occurs after a clean uninstall and reinstall of Fusion 360.
I also wonder if your logs may give any input on this issue. Please gather your diagnostic log files using this procedure and attach them to this forum thread - I am happy to have a look.
Paul Clauss
Product Support Specialist
Message 3 of 22
@paul.clauss, I have a similar issue, I reported here https://forums.autodesk.com/t5/fusion-360-support/startup-hobbyist-cloud-credits/m-p/7907288/highlig... as I was having an ongoing problem with rendering that got solved but I thought this was still related.
Message 4 of 22
paul.clauss
Hi @Anonymous
Please let me know what operating system you are working with (Windows or Mac, version number)? Thanks!
Paul Clauss
Message 5 of 22
JSie
Hi @paul.clauss, as per your request, please find enclosed the diagnostic files. Brief summary: upon updating my MacBook Pro (Intel Core i7) to OS High Sierra 10.13.4 on 4-Apr-2018, I have been unable to download rendered images from the cloud service. Attempts result either (i) in a message "Alert! An error occured while downloading this image. The server may be busy. Please try again later.", or (ii) in a message "Preparing your file for downloading..." that disappears in about 2 seconds with nothing downloaded. I have tried downloading for a couple of times over 24 hours, and while the problem might not be related to the recent OS update decided to report it as possibly related to that.
Any help greatly appreciated!
Message 6 of 22
paul.clauss
Hi @JSie
This issue should be resolved - are you still experiencing problems? Please confirm the behavior on your machine - thanks!
Paul Clauss
Message 7 of 22
Hi Paul,
I'm facing the same problem: when I'm clicking on the download button of a rendered image nothing happen.
I also try to reinstall Fusion360 but nothing have been changed.
My os is macOS  Hish Sierra 10.13.4.
I attached the Fusion360DiagnosticLogs.zip archive
Luca
Message 8 of 22
paul.clauss
Hi @Anonymous
Thanks for posting - I'm sorry to hear you are still unable to download renderings.
Could you paste the address here (https://dnie9zy2a5op.cloudfront.net/fusion/BootstrapConfig.js) into your web browser and share a screenshot of the results? This will help us learn more about this problem.
We appreciate your input! Please let me know if you have any questions.
Paul Clauss
Message 9 of 22
I'm not @Anonymous, but I have the same problem, here's my output:
var vx360webcomponentsBootstrapConfig = {
    cdn: {
        scripts: [
            'https://dnie9zy2a5op.cloudfront.net/release/2.0.37/scripts/vx360.webcomponents.lib.js?bv=4938ff5',
            'https://dnie9zy2a5op.cloudfront.net/release/2.0.37/scripts/vx360.webcomponents.js?bv=4938ff5',
            'https://dnie9zy2a5op.cloudfront.net/release/2.0.37/scripts/vx360.webcomponents.lang.js?bv=4938ff5'
        css: [
            'https://dnie9zy2a5op.cloudfront.net/release/2.0.37/css/vx360.webcomponents.lib.css?bv=4938ff5',
            'https://dnie9zy2a5op.cloudfront.net/release/2.0.37/css/vx360.webcomponents.css?bv=4938ff5'
    settings: {
        useCCW: true,
        useImageServer: true
Message 10 of 22
Hi Paul,
here the requested screen shot
Luca
Message 11 of 22
paul.clauss
Hi @Anonymous@Anonymous
Thanks for the quick responses. Both of your outputs indicate that you should be able to download renderings after restarting Fusion. I would maybe try restarting the whole system for good measure.
I hope this helps! Please let me know the results and we will go from there.
Paul Clauss
Message 12 of 22
Hi Paul
I restarted my machine but the same problem is still there: when I click the download button nothing happen.
(instead when I click the delete button the dialog panel appears as expected.)
I did try to make a new rendering but still nothing happen when I clicked the download button of the new image.
Hope this helps
Luca
Message 13 of 22
@paul.clauss, restarted the Mac, Fusion still crashes when I try to download the render. Sent a crash report. 😞
Message 14 of 22
paul.clauss
Hi @Anonymous @Anonymous
Thanks for the confirmation. I will reach out to the development team and follow up when I have more information to share.
Paul Clauss
Message 15 of 22
@paul.clauss
Thank you.
Downloading a render was never a problem before, this is a bit upsetting, because it's the same for local renders, basically I can't use any render.
Message 16 of 22
JSie
Hi @paul.clauss, I made a couple of quick tries today - no luck yet. The problem still persists, "Preparing your file for download..." is shown for a couple of seconds, then disappears without any files downloaded. This is happening when ever I try to do that from the Fusion 360 application directly. However, what I have not yet tried until now, was to attempt to download the rendered images from the  Autodesk Account (Product & Services / All Products & Services / Rendering / My Renderings) - that works without any problems!
So, for now, there is an easy workaround with which I can live productively.
Message 17 of 22
paul.clauss
Hi @JSie @Anonymous
Thanks for reaching out and sharing your workaround! Our development team has proposed another fix that I will post here for all to try - please let me know if it works for you.
  1. Go to [WINDOWS] <user>\AppData\Local\Autodesk\webdeploy\production\<latest fusion version>\Neutron\Server\BatchRender\Resources\vx360.webcomponents\scripts or [MAC]/Users/<username>/Library/Application Support/Autodesk/webdeploy/production/<latestFusionversion>/Libraries/Neutron/Neutron/Server/BatchRender/Resources/vx360.webcomponents/scripts
  2. there are two files vx360.webcomponents.js, vx360.webcomponents.lib.js.
  3. backup these files elsewhere on your computer
  4. Replace them with the files shared below: vx360.webcomponents.js, vx360.webcomponents.lib.js
  5. Go to [WINDOWS] <user>\AppData\Local\Autodesk\webdeploy\production\<latest fusion version>\Neutron\Server\BatchRender\Resources\vx360.webcomponents\css or [MAC]
    /Users/<username>//Library/Application Support/Autodesk/webdeploy/production/<latestFusionversion>/Libraries/Neutron/Neutron/Server/BatchRender/Resources/vx360.webcomponents/css
  6. there are two files vx360.webcomponents.css, vx360.webcomponents.lib.css.
  7. backup these files elsewhere on your computer
  8. Replace them with the files shared below: vx360.webcomponents.css, vx360.webcomponents.lib.css
The files are shared at this link.
Please let me know how this goes.
Paul Clauss
Message 18 of 22
Hi Paul
I didn't found any path like you suggested /Users/<username>/Library/Application Support/Autodesk/...
but I think, after macOs implemented sandboxing you where referring to the following one:
/Users/<username>/LibraryContainers/com.autodesk.mas.fusion360/Data/Library/Application Support/Autodesk/Autodesk Fusion 360/
BTW the file you specified: vx360.webcomponents.js vx360.webcomponents.css vx360.webcomponents.lib.js vx360.webcomponents.lib.css are located on my machine under the application bundle
/Applications/Fusion360.app/Contents/Libraries/Neutron/Neutron/Server/BatchRender/Resources/vx360.webcomponents/scripts/vx360.webcomponents.js
/Applications/Fusion360.app/Contents/Libraries/Neutron/Neutron/Server/BatchRender/Resources/vx360.webcomponents/scripts/vx360.webcomponents.lib.js
/Applications/Fusion360.app/Contents/Libraries/Neutron/Neutron/Server/BatchRender/Resources/vx360.webcomponents/css/vx360.webcomponents.css
/Applications/Fusion360.app/Contents/Libraries/Neutron/Neutron/Server/BatchRender/Resources/vx360.webcomponents/css/vx360.webcomponents.lib.css
I closed the application, I replaced the original file with the files you shared, I restarted the application but nothing changed: the problem is still there.
Did I miss something?
Luca
Message 19 of 22
paul.clauss
Hi @Anonymous
I just saw some problems with the workaround in this thread and have reached out to our development team for guidance on how to move forward - I'll keep you updated here with any new information I have to share.
Paul Clauss
Message 20 of 22
@paul.clauss, thank you but I'm going to skip making those changes and wait for a fix, in the meantime I'll use @JSie workaround.
