Importing vector files ?
Can anyone suggest a solution (learner)  ... 🙂
Also my system hangs a fair bit with mesh lines all of a sudden shooting away from components ???
Any assistance would be appreciated
Cheers
Greg
ryan.bales
Autodesk Support
Autodesk Support
Hi! Can you elaborate a little more what you are trying to do?
File type, Program, etc?
Ryan Bales
Fusion 360 Product Support
Yeah Hi Ryan, Thanks for the reply 🙂
I am running an older versioon of Coreldraw12 and a program called Affinity (which i find quite good )
I am able create .dwg / eps / svg / png's and jpegs etc .... for export (Nice smooth curves LOL!)
However i just worked out how to import an SVG through the "Insert Menu" which is great - but was quite trucated once extruded is there a way to weld this to be one solid body / component??? ...
Again Cheers mate for your help - appreciated in advance 🙂
Greg
ryan.bales
Autodesk Support
Autodesk Support
I imagine it is possible but hard to say without seeing the exact file.
Just curious, have you tried dwg?
Ryan Bales
LOL as i said OLD version of Cdrw12 pre win10! and its on an old pc a hassle to go back and forth as i cant get the version to new pc ... but yes i'll give that a swing ty!
when Importing is it always best to go through the Insert Menu?
Unfortunately if i try to share a screenshot in the field below it wants to share my whole page even though i hhave cropped just the component to show you!
Sorry no can do! 🙂
I can send you an email with the png.
Cheers Greg
ryan.bales
Autodesk Support
Autodesk Support
Hmm well its hard to do more without having it or seeing more. Even just a sample in .svg would be worthwhile to see what happens.
For the insert option. If its a filetype Fusion accepts i would use the Upload dialog box in the data panel. .dwg is the only one i recall from your list that will upload cleanly. If inserting into design then they way you are doing it is likely fine.
Ryan Bales
