Stuck on "Improve your experience" page
adelahayeQMSPQ
Observer Observer
Message 1 of 18
adelahayeQMSPQ
Observer
Observer
Hello, I made the update, and I'm stuck on the "Improve your experience" page see attachment. There is no way to validate and continue further to use the software. Thank you for your help.
Replies (17)
Message 2 of 18
RajkumarIlanchelian
@adelahayeQMSPQ Thank you for reporting and we are looking into this. Seems to be when the language is changed, we are encountering this. Does hitting enter accept the terms on this page?
Rajkumar Ilanchelian
Autodesk Fusion
Join Fusion Insider
Message 3 of 18
zaka3d
Hi Rajkumar.
I reported the same problem here: https://forums.autodesk.com/t5/fusion-360-support/can-t-open-fusion-on-mac-studio-m1/td-p/11723814
All people with this problem are using French version.
Message 4 of 18
zaka3d
To answer your question. Hitting enter doesn't accept the terms on this page.
Message 5 of 18
studio863NE
Same here!
Message 6 of 18
RajkumarIlanchelian
@studio863NE @adelahayeQMSPQ @zaka3d We are working to address this ASAP. We do believe there is a workaround that can get you past this.
Can you please go into your monitor's display setting and set it to the highest resolution and then launch Fusion? If this does not work then there is one more thing we can try (that I am currently testing) and will post here.
Autodesk Fusion
Join Fusion Insider
Message 7 of 18
zaka3d
Tested with my 4k screen (set to 3840x2160). It doesn't work.
Message 8 of 18
RajkumarIlanchelian
@zaka3d @adelahayeQMSPQ @studio863NE
If screen resolution is not working (looks like it is not) here is the other option that should do it.
Here is a workaround that will get you moving forward:
Windows:
1. Close Fusion 360
2. Go to C:\Users\YOUR USER ID\AppData\Roaming\Autodesk\Neutron Platform\Options
3.Look for the file NMachineSpecificOptions.xml
4. Edit this file
5.Look for the key - <userLanguageOptionId ToolTip="The language used to present the UI." UserName="User language" Value="fr-FR"/>
6. Change fr-FR (or any other language you see here to en-US
7. Now launch Fusion 360
8.It will launch in English
9.Accept the Ui terms etc
10. Once this is done you can go in to preferences and set the language back to your preferred language
Mac:
1. Close Fusion 360
2.Go to /Users/kumYOUR USER ID/Library/Application Support/Autodesk/Neutron Platform
4. Edit this file
10.Once this is done you can go in to preferences and set the language back to your preferred language
Autodesk Fusion
Join Fusion Insider
Message 9 of 18
studio863NE
Thanks for the quick reply.
Some of us are on Mac computers unfortunately.
Message 10 of 18
zaka3d
I'm on a Mac. I found the file under library/application support/autodesk/neutron platform but didn't find the key <userLanguageOptionId ToolTip="The language used to present the UI." UserName="User language" Value="fr-FR"/>
Message 11 of 18
RajkumarIlanchelian
I updated the above post with the Mac locations too.
@zaka3d I am surprised that you cannot find this option but if you are not seeing it, here is what to do.
Add this
<userLanguageOptionId ToolTip="The language used to present the UI." UserName="User language" Value="en-US"/> to the </BootstrapOptionsGroup>
Autodesk Fusion
Join Fusion Insider
Message 12 of 18
studio863NE
All good!
Message 13 of 18
zaka3d
Thanks a lot. After adding this line it's ok.
Message 14 of 18
zaka3d
And after launching one time in English and accept the terms, reverting to fr-FR works as well.
So everything is perfect.
Message 15 of 18
michael.bonhomme
Community Visitor
Community Visitor
Adding my 2 cents : on my Mac (Mac mini M1 on Ventura) NMachineSpecificOptions.xml is under
/Users/<user>/Library/Application Support/Autodesk/Neutron Platform/Options
Message 16 of 18
basile1
Observer
Observer
I'm having the same problem here but impossible to find the file "Neutron Platform" on mac. It also doesn't work with the screen resolution... (Fusion in french also).. HELP
Message 17 of 18
RajkumarIlanchelian
@basile1 Can you post an image of your path?
Autodesk Fusion
Join Fusion Insider
Message 18 of 18
basile1
Observer
Observer
for going to wich file ?
