I have a 100 mm hollowed sphere with a two millimeter shell. When I dig a hole from the inside face of the sphere, because it is a rounded surface, there is a flat plane formed at the beginning and then the rest of the hole is dug, as it digs from the center point of the start of the hole on the chosen face.
I can then complete the hole by extruding. Alternatively, I can create the hole in the first place by extruding.
Is this expected behavior? Is there a way to set the parameter for hole depth to begin from a negative depth?
