@zaka3d @adelahayeQMSPQ @studio863NE
If screen resolution is not working (looks like it is not) here is the other option that should do it.
Here is a workaround that will get you moving forward:
Windows:
1. Close Fusion 360
2. Go to C:\Users\YOUR USER ID\AppData\Roaming\Autodesk\Neutron Platform\Options
3.Look for the file NMachineSpecificOptions.xml
4. Edit this file
5.Look for the key - <userLanguageOptionId ToolTip="The language used to present the UI." UserName="User language" Value="fr-FR"/>
6. Change fr-FR (or any other language you see here to en-US
7. Now launch Fusion 360
8.It will launch in English
9.Accept the Ui terms etc
10. Once this is done you can go in to preferences and set the language back to your preferred language
Mac:
1. Close Fusion 360
2.Go to /Users/kumYOUR USER ID/Library/Application Support/Autodesk/Neutron Platform
4. Edit this file
10.Once this is done you can go in to preferences and set the language back to your preferred language
