INTERNAL ERROR : !dbentapi.cpp@741 : eNullObjectId
Marceliiin
Message 1 of 9
Marceliiin
Hi there,
This message (INTERNAL ERROR : !dbentapi.cpp@741 : eNullObjectId) pops up when every time I try to edit or create a Title Block in the Drawing workspace, after I close the window.
Does anyone encounter this ?
Replies (8)
Message 2 of 9
suryawa
Hi @Marceliiin ,
We are very sorry to hear about this issue.
  • Do you see this issue persistent with all files or is it data specific issue?
  • Since we are not able to reproduce this issue in-house, a sample data file will help us to analyse the problem more precisely.
Thanks & regards
Amit Suryawanshi
Fusion SQA
Amit Suryawanshi
SQA Fusion 360
Message 3 of 9
Marceliiin
Hi @suryawa ,
Yes this issue is persistant with all files...
How can I get this sample ?
Message 4 of 9
baribak
You can share the file by right-clicking on the file in the Data Panel and choosing Share.
Can you try starting Fusion by right-clicking on the desktop icon and choosing Run as Administrator? Then try opening the file, etc. and see if it helps. Checking to see if this is a "rights" issue.
Kevin Baribault
Fusion 360 Quality Assurance
Message 5 of 9
Marceliiin
Here is the link : https://a360.co/365ySY2
I tried running it with administrator run, didn't change anything.
Message 6 of 9
suryawa
Hi @Marceliiin ,
Thank you for sharing the sample file.
In addition to the internal error issue, we also see another problem;
Adding a new sheet to the drawing file you shared, shows title block & canvas are not in sync...!
That indicates the drawing file is damaged..!
I am reporting this issue internally for tracking purpose.
Meanwhile, can you please try a clean installation and see if this issue still persists?
Thanks & regards
Amit Suryawanshi
Fusion SQA
[email protected]
Amit Suryawanshi
SQA Fusion 360
Message 7 of 9
Marceliiin
Hi @suryawa,
I have an other error message when I tried to open a drawing, It might comme from there :
                                                           " DLL not found : hcreg16Res.dll "
I do not find it on internet and don't know where to install it...
Tank you for your time !
Marcelin
Message 8 of 9
Marceliiin
@suryawa
I also tried a clean installation, unfortunately, nothing change...
Message 9 of 9
ClintBrown3D
Hi @Marceliiin
Good news, this has been resolved in the November release of Fusion 360 (which should be available imminently)
More info here:
https://forums.autodesk.com/t5/fusion-360-support/november-2021-product-update-improvements-known-is...
Clint Brown
Senior Product Manager - Autodesk Fusion
Book some time on my calendar
The Ultimate Guide to Drawing Automation
