I have some problem with joint component.
I want to joint two parts like above diagram.
But I only can use one joint point to assemble two component.
And I can't select another point to joint again.
I don't want to use align or rotate to align two parts.
Can I use joint to assemble two components.
Thanks.
you can capture the rotation in the Joint itself (different than using Move/Rotate or Align, because it is associative)
