Fusion Support
Report issues, bugs, and or unexpected behaviors you’re seeing. Share Fusion (formerly Fusion 360) issues here and get support from the community as well as the Fusion team.
How to joint two component with multiple points
3 REPLIES 3
269 Views, 3 Replies
I have some problem with joint component.
I want to joint two parts like above diagram.
But I only can use one joint point to assemble two component.
And I can't select another point to joint again.
I don't want to use align or rotate to align two parts.
Can I use joint to assemble two components.
Thanks.
Tags (1)
3 REPLIES 3
g-andresen
2 Revolute joints will do it
Screencast
günther
jeff_strater
you can capture the rotation in the Joint itself (different than using Move/Rotate or Align, because it is associative)
Jeff Strater
Engineering Director
in reply to: jeff_strater
Thanks a lot, it works
