I want to fillet all corners and have to fillet the backside seperate, but at one corner the fillet some times changes after I klick on finish. Can anyone help me?
Here my 3D moddel:
Hello Jonathan-
I wasn't able to recreate the issue you showed. The only thing I can think of is maybe when you are picking one of the variable blend points, it isn't catching to the exact start/end of the edge.
I created a video showing my process and that it works.
Brad
Hello Brad,
Thank you for your response. Just for recreational purposes, you took another point for the fillet.
I tryed it out myself and it works if I use another green snaping point, but if you use the point at the corner of the 10mm fillet then I am still able to recreate this issue. If I use another point, what would have been my next attempt, then you are not able to recreate this issue.
I have uploaded another Screencast (https://autode.sk/3uqjGzh) to show the difference.
I can recreate the issue, that my fillet jumps to another pattern if I click on finish if I set the middle fillet point on 0.905.
So I tryed the workaround, and it worked.
But now my save is corupt and I think it is related to this fillet..
I opened another forum entry for this.
Here the link to my corupt file post: (https://forums.autodesk.com/t5/fusion-360-support/corupt-file-after-fillet/m-p/10345396)
Short update:
I created a new model looking like this one and if I create the fillet on this one edge wit the middle point at the 10mm fillet snaping point the pattern changes as I click on finish.
Here is the new version of my model with the same issue.
Hello @tallisb,
can you maybe try this again with setting the middle point to the 10mm fillet, as I exlained earlyer in this post?
In my oppinion it is driectly linked to the corrupt file after saving problem wich I explained here: https://forums.autodesk.com/t5/fusion-360-support/corupt-file-after-fillet/m-p/10350421#M124154
Greetings, Jonathan
