Fusion Support
Report issues, bugs, and or unexpected behaviors you’re seeing. Share Fusion (formerly Fusion 360) issues here and get support from the community as well as the Fusion team.
Fillet Bug
7 REPLIES 7
Message 1 of 8
JonathanB3
389 Views, 7 Replies
Fillet Bug
I want to fillet all corners and have to fillet the backside seperate, but at one corner the fillet some times changes after I klick on finish. Can anyone help me?
Here my 3D moddel:
https://a360.co/3yDozYY
Here the Screencast (idk. why, but I cant attach it direct to this forum):
https://autode.sk/3bQO6nI
Labels (1)
7 REPLIES 7
Message 2 of 8
tallisb
in reply to: JonathanB3
Hello Jonathan-
I wasn't able to recreate the issue you showed.  The only thing I can think of is maybe when you are picking one of the variable blend points, it isn't catching to the exact start/end of the edge.
I created a video showing my process and that it works.
https://autode.sk/3bSVyio
Brad
Brad Tallis
Fusion 360 Technical Specialist
Message 3 of 8
JonathanB3
in reply to: tallisb
Hello Brad,
Thank you for your response. Just for recreational purposes, you took another point for the fillet.
I tryed it out myself and it works if I use another green snaping point, but if you use the point at the corner of the 10mm fillet then I am still able to recreate this issue. If I use another point, what would have been my next attempt, then you are not able to recreate this issue.
I have uploaded another Screencast (https://autode.sk/3uqjGzh) to show the difference.
I can recreate the issue, that my fillet jumps to another pattern if I click on finish if I set the middle fillet point on 0.905.
Message 4 of 8
JonathanB3
I will just use another point for my middle fillet marker to avoid this problem, but maybe check the .905 posittion again.
Maybe it is just a hardware related bug on my end, but who knows.
Message 5 of 8
JonathanB3
So I tryed the workaround, and it worked.
But now my save is corupt and I think it is related to this fillet..
I opened another forum entry for this.
Here the link to my corupt file post: (https://forums.autodesk.com/t5/fusion-360-support/corupt-file-after-fillet/m-p/10345396)
Message 6 of 8
JonathanB3
Short update:
I created a new model looking like this one and if I create the fillet on this one edge wit the middle point at the 10mm fillet snaping point the pattern changes as I click on finish.
Message 7 of 8
JonathanB3
Here is the new version of my model with the same issue.
Message 8 of 8
JonathanB3
Hello @tallisb,
can you maybe try this again with setting the middle point to the 10mm fillet, as I exlained earlyer in this post?
In my oppinion it is driectly linked to the corrupt file after saving problem wich I explained here: https://forums.autodesk.com/t5/fusion-360-support/corupt-file-after-fillet/m-p/10350421#M124154
Greetings, Jonathan
Technology Administrators
