Fusion Support
Chamfer millng
3 REPLIES 3
539 Views, 3 Replies
Chamfer millng
hi.
I have problem chamfer. I select edge and tool path is inside the part.
I have delete whole project and after that I have correct tool path.
but when I create another part I have same problem again . inside  chamfer is correct, but outside tool path is on the material side.
any solution how to correct it?
why tools going on material ?
3 REPLIES 3
paul.clauss
Hi @Anonymous
Thanks for posting! Are you certain that the arrow for the chamfer operation is on the correct side of the selected outer contour? chamfer side.gif
 Hopefully this helps! Please let me know if you have any questions!
Paul Clauss
Product Support Specialist
in reply to: paul.clauss
Yes. Arrow is on correct site.
paul.clauss
Hi @Anonymous
Thanks for the response! It may help me diagnose this issue if I could have a look at your file - would you mind sharing it with me using any of the techniques at this link
Paul Clauss
Technology Administrators
