hi.
I have problem chamfer. I select edge and tool path is inside the part.
I have delete whole project and after that I have correct tool path.
but when I create another part I have same problem again . inside chamfer is correct, but outside tool path is on the material side.
any solution how to correct it?
why tools going on material ?
Hi @Anonymous
Thanks for the response! It may help me diagnose this issue if I could have a look at your file - would you mind sharing it with me using any of the techniques at this link?
