Message 1 of 9
I tried using the trick where you drag a sketch into a component if you forgot to create one when you start designing a part. It looks like it works until you try adding another flange then Fusion crashes.
Edit I see where I went wrong, I used the right click on the main component to create a new component not the New Component from the toolbar in the sheetmetal workspace.![]()
I'll attach a screencast later, it looks like the outage that's taken Fusion offline is affecting screencast uploads as well.![]()
Mark
Mark Hughes
Owner, Hughes Tooling
