Sheetmetal Crash
Sheetmetal Crash
HughesTooling
Consultant Consultant
Message 1 of 9
Sheetmetal Crash
HughesTooling
I tried using the trick where you drag a sketch into a component if you forgot to create one when you start designing a part. It looks like it works until you try adding another flange then Fusion crashes.
Edit I see where I went wrong, I used the right click on the main component to create a new component not the New Component from the toolbar in the sheetmetal workspace.Smiley Embarassed
I'll attach a screencast later, it looks like the outage that's taken Fusion offline is affecting screencast uploads as well.Smiley Mad
Mark
Mark Hughes
Owner, Hughes Tooling
Replies (8)
Message 2 of 9
gautham_kattethota
Hi Mark,
Trying to reproduce the issue, but I dont see the crash.  Would be good if you can add a screencast.
One thing to note - if you create a regular (non-Sheetmetal) component by clicking on NewComponent command in the right click of a component in the browser, it does create a regular component. If you however add a sheetmetal flange feature to it, it is automatically converted to a sheetmetal component.
Regards
Gautham
Gautham Kattethota
Software Development
Message 3 of 9
HughesTooling
Hi Gautham
Here's the screencast I recorded I also filed in the crash reports.
Mark
Mark Hughes
Message 4 of 9
gautham_kattethota
Hi Mark,
I can reproduce this crash.  Thanks for sharing the screencast, helped a lot.  We will fix this issue soon.
Regards
Gautham
Gautham Kattethota
Message 5 of 9
keqingsong
This is getting fixed in our April 12 update!
Keqing Song
Autodesk Fusion Community Manager
Portland, Oregon, USA
Become an Autodesk Fusion Insider
Message 6 of 9
HughesTooling
Hi @keqingsong Did the April 12 update get pushed back?
Also how did you end up with minus 17 ideas, do they take points away if it's a bad idea?Smiley Surprised
Mark
Mark Hughes
Message 7 of 9
brianrepp
@HughesTooling - yep, the April 12th update was pushed back.  Hopefully should go out this week!
LOL at Keqing and all of his negative ideas. Smiley Wink
Message 8 of 9
daniel_lyall
Keqing cursed the updateSmiley Tongue, he should never give a date.
Daniel Lyall
The Big Boss
Mach3 User
Facebook | Twitter | LinkedIn
Message 9 of 9
HughesTooling
Waiting for Keqing's ideas to change to minus eighteen.Smiley Tongue
Mark
Mark Hughes
