Inconsistent UI
Inconsistent UI
kellings
Advisor Advisor
Inconsistent UI
kellings
creating a contour flange has an inconsistent UI compared to the extrude command in the model. You can create a symmetric contour flange extrusion, but the value you enter is half the value you want the total flange extrusion to be. In the model environment, we can can choose overall or half.
In the image below the extrude command on the left is from the model workspace and the one on the right is from sheetmetal.
Kevin Ellingson
Technical Specialist
If my post resolves your issue, please click the Accept Solution button.
patrick.miller
Thanks for the feedback and the images (images help a ton to get what you're describing). This is on our list of finishing tasks for flange. I don't think it was available when we originally did control flange.
This also applies to an edge flange with the symmetric option:
Patrick Miller
User Experience Designer
Fusion 360 Learning
