Fusion Manufacture
rotary axis machining
1 REPLY 1
msm19b034
141 Views, 1 Reply
In the picture the setup is done for rotary axis machining where the piece rotates with axis as X axis and machining happens in linearly in x and y direction. is it possible to perform machining where all the three axes move simultaneously. currently the piece rotates by a step angle and then machining takes place. i want to know if there is an option to perform the rotation and machining simultaneously.
1 REPLY 1
engineguy
in reply to: msm19b034
@msm19b034
Yes, you can do this using the "Rotary" strategy which you will find under your "Multi-Axis" tab.
The part will rotate around the X axis and the Z axis wil move up and down to the shape of the Model selected, you only need the two axis A around the X and the Z to be moving to do the shape in your image.
